Number of posts : 7963
Most modern engines only use a 5 or 10w grade oil. A 25w is quite thick and takes longer to build up pressure from cold. Over time with stop start that increases wear. To use that grade in winter would definitely not be good, I still would not put that oil in. I can't remember which grade goes in but I think mine is on 10w40. The K does go back to 1983 but the engine was quite advanced at that time. The oil pu
Whatever about the oil I reckon it is the cause of the knock because I have come across that before.
1971 Yamaha 125 YAS-1
