Fuel Injectors - Any Good? Tue Nov 03, 2009 4:46 pm
cbjroms
![avatar](https://i.servimg.com/u/f41/11/71/56/74/avatar10.jpg)
![New member New member](https://2img.net/i/itest/ranks/default/default1.gif)
I am in the process of stripping down my 8valve K100 engine.
When I removed the fuel rail from the head the fuel injectors remained in the head rather than coming away with the rail. It then took quite alot of 'coaxing' to get each of them out of the head. In fact, when I pulled the injectors out of the head the rubber O ring and cream plastic cap were left behind. The Haynes manual suggests it should all come out together!
Can I just push the plastic caps back on and replace O rings? Or, now that the caps have come off, do I need new injectors?
Chris
Chris
