1Back to top Go down   Valves in motion Empty Valves in motion Fri Feb 19, 2010 6:44 am
This is interesting to see the valves rotating at high rpm(Check the red mark on the spring pocket)
Valves in motion Frog15Valves in motion Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
2Back to top Go down   Valves in motion Empty Re: Valves in motion Fri Feb 19, 2010 3:51 pm
Bruce
Bruce
cool video, question tho, is the mist (smoke?) coming out at higher RPM just misted oil, or is it steam boiling off the engine after a bit of a sit? just curious. cheers B
3Back to top Go down   Valves in motion Empty Re: Valves in motion Fri Feb 19, 2010 10:11 pm
I believe that it is only misted oil.
I cannot see the valves leaking and the compression coming up in the valve cover. The pressure would take the path of least resistance and go into the exhaust pipe.
The question is why the valves are turning..... This is good as the valves are wearing evenly, but why only at high rpm?
