1 Right Hand Fork Leg - K100RS 1983 Sat Jun 29, 2013 3:03 pm
Shug
Hello,
Right Hand Fork Leg on my K100RS 1983 does not match my left hand leg. Under investigation the filling bolt at the top of the leg had a bolt with a piece of 'rubber' hose fitted pushed into the hole.
I'm sure this isn't right.
Looking through the parts manual only shows 1 leg which just has a filling bolt with a sealing washer. Haynes isn't clear either.
Looking down the hole there appears to be a couple of O-rings and some ports? so my guess is some form of adjustment.
Not sure if these are the correct legs?
Can anyone help with what should be going on/in here. Some photo's are always a great help.
Hugh
Hugh
