1 Swing Arm Bearings Sun Jun 23, 2013 12:46 pm
otto59
Has anyone used FAG 30203 instead of 540619 in a K100? Any modifications?
But you need to get spacers machined (unless someone sells them). That would probably bring the cost up to the same as buying the called for bearing.the.postman wrote:Just a note.
If I'm not mistaken the 540619 is a sealed bearing and the 30203 has no seal.
Other than ease of re-greasing this shouldn't make much difference.
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Swing Arm Bearings
Similar topics
