bmwk100rs
bmwk100rs
In this video, Chris Harris installs the drive shaft first and then the swing arm.
https://youtu.be/EKfD76cF8bk?t=1481
However, the Haynes and Clymer books instruct you to do it the other way around. So, which one is the way you guys follow?  TIA!
Personally, for me it's six of one and half dozen of the other.  I've done it both ways but prefer having the swing arm in place first.
When I do the annual spline lube on my bikes, I just remove the final drive and pull the drive shaft.  I use Vise Grips clamped on the end of the shaft to pull it out.  Putting it back, I slide the drive shaft into the swing arm and line up the splines onto the transmission output shaft, then drive it home with a rubber mallet until the clamp ring locks onto the output shaft.
If I'm not mistaken, Chris Harris has also removed and reinstalled the drive shaft while leaving the swing arm in place.
I always take the swingarm off, then I can inspect the splines and other hidden things, also adjust the bearings again when I place the arm back.
Which one goes first, the swing arm or the shaft? Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
bmwk100rs
bmwk100rs
Arlina wrote:Also adjust the bearings again when I place the arm back.
What do you mean with adjust the bearing? Replace them if they are not rotating freely?
The swingarm pivot on the right side of the bike (the one with three small allen-headed bolts) WILL seize if it isn't pulled and greased. The one on the left isn't so prone to seizing but it can still corrode on quite badly. If the right-side one is corroded in, it will take a lot of patience and penetrating oil (NOT WD-40 or similar) to remove it. I had one that was so bad it didn't finally give up until attacked with an 18" pipe wrench. The pivot is still in use Very Happy
To answer your original question: if the swingarm and the shaft are off, I always put the shaft back on first so that I can be sure it is locked in place. There's enough clearance at the bevel drive to allow you to twist it about a bit to slide into the driveshaft.
The pivot on the right is fixed, the pivot on the left is to adjust the bearings of the swingarm.
There is a torq setting for, altough I never use that (feeling).
That is because some idiots use Loctite, the leftovers from it work against the low torq setting, wich make the pivot too loose.
bmwk100rs
bmwk100rs
Arlina wrote:The pivot on the right is fixed, the pivot on the left is to adjust the bearings of the swingarm.
Gotcha. Thanks Arlina for the clarification.  Do you also check that the bearings are fully packed with clean grease?  If so, then what kind of grease/lube do you use on those bearings?
Ofcourse.... No half job Very Happy
Every bearing grease is good, no special shit needed.
I think you're having two different conversations.
- any bearing grease will do for the swingarm pivots
- the bearings in the swingarm are the 2RS type (fully sealed), so there's no regreasing involved.
Dai wrote:I think you're having two different conversations.
Yeah, I was confused about what they were talking about because I have sealed bearings on the swing arm pivots and never greased them.  The retainers are given a wipe of anti-seize as a rust preventative  just to make disassembly easier.
bmwk100rs
bmwk100rs
Dai & Point-Seven-five,
Thanks for the clarification. Besides the pivots, I wanted to know if I also had to remove the black plastics dust cover, add grease, and place it back (see arrows below). It seems that it's not necessary since they are 2RS type beatings, correct?
Both bearing rotate freely and I know a special tool or a slide hammer is needed to remove them.  However, they have a small play if I gently try to pull them out of the swing arm casting. They come off ~1-2mm out of the swing arm.  Is that normal?
 Which one goes first, the swing arm or the shaft? Img_1212
Which one goes first, the swing arm or the shaft? Img_1211
Which one goes first, the swing arm or the shaft? Img_1213
bmwk100rs wrote:Thanks for the clarification. Besides the pivots, I wanted to know if I also had to remove the black plastics dust cover, add grease, and place it back.
What you'll see if you remove the "dust cover" is likely to be what is in the left-side image below. It's the seal of the sealed bearing. The photo is from Max BMW's parts fiche.
The play you've encountered is some of what the adjustable pivot adjusts when it's adjusted.
Which one goes first, the swing arm or the shaft? Swinga11
bmwk100rs
bmwk100rs
Laitch wrote:What you'll see if you remove the "dust cover" is likely to be what is in the left-side image below. It's the seal of the sealed bearing.
Got it. Thanks a lot Laitch!
The play is taken out when you install the swing arm pivot pins.  First is the right side with the three 6mm screws.  Tighten them to 6 or 7 foot pounds.
Then the left side is installed.  Tighten the adjustable pivot pin with an Allen key to 5.5 foot pounds and then tighten the lock nut to 30 foot pounds while holding the pivot pin with the Allen wrench.  I cheat by giving the lock nut a good tweek with an open end wrench/spanner while holding the pivot pin, and then following up with the final tightening with a socket and a torque wrench.
Just for clarification, before you all have the idea I drink too much wine Razz
The original bearings are sealed, I only check if they run smooth or feel dry, sits well in the housing, etc....
Sometimes I face an old K wich had the bearings replaced, but not the originals wich BMW uses.
They have 1 sealcap, behind it can see the rolls.
Once I found a ballbearing Evil or Very Mad  on only the right side...... (replaced both bearings to make sure bike is good again Smile )
It's easy to see how bmwk100rs took to a trip to the weeds, especially if b had read threads like this one, this one and this one. Context is everything, especially when inexperience and trust issues are involved. Laughing Clarity came through in this thread though. Which one goes first, the swing arm or the shaft? 112350
bmwk100rs
bmwk100rs
I followed all the steps and sequence to install the swing arm and the only resistance it seems to be from the rubber boot. Is the space gap between the left vs the right bearings within spec?
Which one goes first, the swing arm or the shaft? Img_1215
Which one goes first, the swing arm or the shaft? Img_1214
Which one goes first, the swing arm or the shaft? Img_1216
bmwk100rs wrote:Is the space gap between the left vs the right bearings within spec?
The right side gap is fixed. The left-side gap and pin length make adjustment possible. The only "spec" is the left-side torque value. Attached is a photo of the left-side gap of my pristine Brick's swing arm. I couldn't ask for a more comfortable and responsive moon rover for navigating the gravel wastelands we call town roads here.
Which one goes first, the swing arm or the shaft? Img_0310
bmwk100rs
bmwk100rs
Laitch wrote:The right side gap is fixed. The left-side gap and pin length make adjustment possible. The only "spec" is the left-side torque value.
Gotcha.Thanks Laitch!  Lubed shaft and final drive are now installed.
Which one goes first, the swing arm or the shaft? Img_1217
