101 Re: Engine misfiring when warm Wed Jun 26, 2013 4:31 am
GerryP
What you see when the ignition is on but the engine is not running is correct (36 psi).
Needle vibration is caused by pressure drop when the injectors open.
This may be a result of fuel supply constriction not allowing fuel flow to keep up with demand. Could be caused by any of the problems listed in my last post plus blocked fuel filter if you haven't changed it. Very important to install it the right way round.
Injectors are turned off during deceleration hence no needle vibration. 28 psi is too low, should stay at 36 psi (I don't think the pump is off).
Best,
ps. Be careful of the pipe to the fuel pressure gauge, you've fuel at 36 psi in there, if it comes off at speed you've got a serious fire hazard.
Best,
