Thanks, great advice, how simple are the K mechanicals when regular maintenance done, though the shafts were marketed as maintenance free, nothing really is, but how often do I service my car diff, new oil every 50000 km or more?. That Honda Moly mentioned is that graphite grease?? the Teflon stuff sounded interesting ? Re blocking the hollow shaft, I wonder if a frost plug might do it, tapped in??? or a neoprene bung tapped in? probably best just to lube her regular. Does the shaft actually oscillate up and down with swing arm arc movement? I thought once bolted up the length was set as its a monolever, unlike a paralever? great vid anyways.
mawhera
Rick
