1Back to top Go down   Oil leak ... Empty Oil leak ... Sat Jan 05, 2013 4:30 pm
kenny byrne
kenny byrne
Hi there and a very good riding year ahead to all,
Sorry .....Now the serious stuff
Went on leave and when returned found oil puddle,
Is there a seal between the oil pump and engine,
I am using Castrol 20w50 high mileage ,will that make it sweat out?
what to do,...please help as I had a flat back tyre yesterday while riding,
Has been fixed thankfully.Cleaned out brake while the wheel was off...
Thanks once again
Kenny
1985 K100 RT eng no# 37840220 ( 0022841)
2Back to top Go down   Oil leak ... Empty Re: Oil leak ... Sat Jan 05, 2013 4:47 pm
walfish
walfish
There are 2 seals, water and oil, best is to remove the pump but have a look on the forum there have been many posts with pics. 20w 50 oil is fine
Google it . mech
Lekker bly
Oil leak ... Uk-log10
                            88 K 100  0033026 (gone)
                            92 K 1100 LT  6455097 (gone)
3Back to top Go down   Oil leak ... Empty Re: Oil leak ... Sun Jan 06, 2013 11:23 am
sounds like oil pump seal has let go .....after many years i might add .....+1 on the threads for replacement of both , as they have to be done together ....]
there is a kit ...including new impeller ....highly recommended
4Back to top Go down   Oil leak ... Empty Re: Oil leak ... Sun Jan 06, 2013 11:48 am
MT350Explorer
MT350Explorer
If the oil is coming from the tell-tale hole beneath the oil/water pump then yeah oil seal gone.The oil seal is beneath the water seal so must be done as a pair. Some good info in Clymer manual and in the 'How to' section of the forum. I just did mine, thread here (more links in it to other threads too)
https://www.k100-forum.com/t4749-oil-water-pump-seals-replacement
Dave
1991 K100 RS 16 valve
5Back to top Go down   Oil leak ... Empty Re: Oil leak ... Sun Jan 06, 2013 12:41 pm
It helps all to know which model you are referring to (though not so much with a typical water/oil pump seal drip) so it's always a good idea to have the year/model info plopped down at the bottom of your signature so's we can quickly see, since you don't mention it specifically in your request for help.
Cheers, and bummer about the flat too.
