2 Re: Oil leak Tue Oct 17, 2017 6:28 am
Number of posts : 7949
I did that job back in February and did everything else while in there.
A few things....
New rear seal....get the BMW one, not the alternatives.
New O ring.
I put in new clutch plate, Sachs is good and they make the BMW ones so don't buy the BMW badge.
Also new clutch bolts, flywheel nut.
Did the gearbox and final drive seals too.
Also replaced driveshaft boot, clutch pushrod boot and their clips, clutch pivot arm bearings [pig to get old ones out].
If you are in that far worth taking out sprag clutch and doing a clean on it.
I knew my alternator monkey nuts were good, but easy enough to get at any time.
New exhaust nuts, studs, gaskets.
WD40 the whole darn lot for ages before hand, anything you need to be opening including the exhaust studs/nuts, . Its so worth it.
1971 Yamaha 125 YAS-1
