Number of posts : 7969
It sounds like the old oil/water pump problem. I had mine done last year. Same thing.
For what its worth there was a change in the impeller from a nut fixing to a bolt. Chances are the shaft etc is all kaput and for my money I would go the complete replacement shaft/seals/impeller kit and be done with it. The replacement parts are an upgrade from the original. Its a little tricky for a novice as the seals are fragile but its a diy job for anyone with good skills but must be done very carefully.
Edit: Mine also is 84 build date. Just go for the complete shaft/seals/impeller kit. When mine was opened up the shaft was not good.
1971 Yamaha 125 YAS-1
