1Back to top Go down   ugly photos Empty ugly photos Tue Nov 13, 2012 6:43 am
Now there are only a couple of reasons this should look so ugly ...I am hoping its the easier option.
ugly photos Sany0140
ugly photos Sany0137
KKlompy ugly photos 2854237993
ugly photos Au-log10
2Back to top Go down   ugly photos Empty Re: ugly photos Tue Nov 13, 2012 6:48 am
It seems like you got the engine oil in the wrong place.
3Back to top Go down   ugly photos Empty Re: ugly photos Tue Nov 13, 2012 6:49 am
It has that sort of Cappuccino look...thick and frothy....lekke mmmmm
4Back to top Go down   ugly photos Empty Re: ugly photos Tue Nov 13, 2012 6:52 am
Water/oil pump overhaul needed I`ll guess, and check the weep hole passage.
5Back to top Go down   ugly photos Empty Re: ugly photos Tue Nov 13, 2012 6:53 am
That aint ugly I thought you might have been looking in the mirror.
And oh boy are you gonna have fun cleaning the radiator out. I have had good success using some water soluable degreaser in the water and changing it a few times.
Also when it comes to refilling you can get the tank up and far enough to the left to get at the filler without removing the fuel lines, makes it easier.
How is the oil got any water in it?
6Back to top Go down   ugly photos Empty Re: ugly photos Tue Nov 13, 2012 7:12 am
Rick G wrote:I have had good success using some water soluable degreaser in the water and changing it a few times.
Dishwashing liquid can also be used for this..................
use all of it, then you have a good excuse for not to do the dishes this evening.
Rinse through with plenty of clean water afterwards.
7Back to top Go down   ugly photos Empty Re: ugly photos Tue Nov 13, 2012 7:22 am
Have my morning fresh handy...lemon scented ...that should sort the radiator...and i have dumped the oil and filter...there was a half inch of water in the bottom of the sump.
Now to strip it all down and re seal it yippee....taking my time and may even get some new 515 master gasket as the old tube I have is way past its use by date.
8Back to top Go down   ugly photos Empty Re: ugly photos Tue Nov 13, 2012 7:27 am
Since you also got water in the oil, it points in the direction headgasket problem.............quite seldom on a K.
9Back to top Go down   ugly photos Empty Re: ugly photos Tue Nov 13, 2012 7:36 am
and or the presure of the hot water blowing back into the oil passages on stop but still hot inge ....well its an attempt to save klompy from pulling the head off straight away .... at least
do the repair klompy ...and then take a second look after a few ks i recon .
10Back to top Go down   ugly photos Empty Re: ugly photos Tue Nov 13, 2012 7:53 am
Yes...I would also first have overhauled the pump, then closely watched the expansion tank and the oil level eye closely on the trips afterwards.
As said headgaskets is seldom a problem on a K, but must be kept in mind as it also could be the reason.........
11Back to top Go down   ugly photos Empty Re: ugly photos Tue Nov 13, 2012 6:42 pm
That is a mess.
I cannot imagine what you were thinking the first time you saw that.
If you need/ want a hand let me know.
Maybe between two of us we could know our heads together hard enough to get some results.
Do as Charlie said. Fix the pump, clean it and run it. Hopefully it is not the head.
Got mine back together last night and went for a ride.
Definately better than the run to Bingara, but maybe needs a balance. If only someone I know close by had a set of balance thingys ugly photos 652573
12Back to top Go down   ugly photos Empty Re: ugly photos Tue Nov 13, 2012 6:47 pm
And check the rad seal, Klompy, mine swelled when it got contaminated with oil and restricted return flow from the reservoir tank.
Just a thought.
13Back to top Go down   ugly photos Empty Re: ugly photos Tue Nov 13, 2012 11:20 pm
Toto_jp
Don't use OMO in the radiator whilst it cleans great , smells good its a bugger to flush if it gets lumpy/clots in the radiator Embarassed
get some engine flush to get rid of the water in the block and order a couple of new oil filters you'll need them
hopefully its only the pump good luck
cheers Tony
K100 RS 1986
14Back to top Go down   ugly photos Empty Re: ugly photos Wed Nov 14, 2012 5:11 am
thanks guys have the pumps back together and fitted....took the advice re ensuring surface flat and clean, put sealant on both surfaces till tacky and then bolted it together....have a place here called Buttsworth engineering and they provided all new allen head screws (stainless) for $7...now will wait till tomorrow to fill with oil and water, new oil filter already in position.
Am hoping that this will come good....would be disappointed if the head gasket has to be changed...but being the eternal optimist that would be another opportunity to pull her apart. Very Happy notice I even painted the pump and front cover....thats going to last 5 minutes...
ugly photos Sany0141
ugly photos Sany0142
15Back to top Go down   ugly photos Empty Re: ugly photos Wed Nov 14, 2012 4:07 pm
Klompy, great job with the paint work. Notice you went to the trouble of putting red pin stripes on it as well...nice.
16Back to top Go down   ugly photos Empty Re: ugly photos Wed Nov 14, 2012 5:01 pm
They look more....orange from here!
17Back to top Go down   ugly photos Empty Re: ugly photos Wed Nov 14, 2012 5:06 pm
my thats a lot of sealant klompy
she'll be right mate
18Back to top Go down   ugly photos Empty Re: ugly photos Wed Nov 14, 2012 10:36 pm
I was going to say orange....but I thought you would have seen enough of that colour at Bingara.
19Back to top Go down   ugly photos Empty Re: ugly photos Wed Nov 14, 2012 11:46 pm
Thanks gents...or should I sat "Statler and Waldorf" funny buggers!
You will be happy to know I peeled of the excess orange sealant after it had set so the decorative pinstriping is no more.....I have now taken the tank off...pretty easy although a tad messy given the almost full tank and sure enough there is the radiator cap...what a crap place to put it, would it have hurt to have it accessable with the tank fitted? Anyhow will fill this up with dishwashing liquid and water and try to work out how I can have the tank fitted, cap off and run water into the radiator to flush?...balancing the tank perhaps?
Would not be an issue if the elec connection and rubber plumbing were longer...may have to jury rig something. Also took the thermostat out ..wow was that unattractive...oh well hopefully the soapy detergent mixture will clean all the old oil out..and even more hopefully I will find that the head gasket is healthy.
20Back to top Go down   ugly photos Empty Re: ugly photos Thu Nov 15, 2012 3:22 am
charlie99 wrote:my thats a lot of sealant klompy
+1.
If you use to much sealant in the area where the pressure relief valve return passage is,
you could get a problem with this passage getting blocked.
Then you would achieve a leak at this spot, ..........and you`re not the first one.
ugly photos Retur_10
21Back to top Go down   ugly photos Empty Re: ugly photos Thu Nov 15, 2012 3:29 am
just a reminder klompy .. as inge i think suggested
dont forget to take off the filler cap and clean up the valving through there .....btw you will probably find the expansion tank full of oil ( should that be creamed mayonaise )...and the level indicator tube really hard to see inside ...from memory about 4 inches of about 9mm id clear hose will fix the invisible water level .....but ... after you have it all cleaned up and running propper like eh?
bows head ....yes inge im guilty of that one too .....but its all fun to learn new stuff Very Happy
22Back to top Go down   ugly photos Empty Re: ugly photos Thu Nov 15, 2012 4:05 am
Halo
Halo
Inge K I was thinking the same thing as just went through that part with the circlip ordeal on the aux drive, the first time I did this I blocked the hole and only noticed when I had to go back in the second time around.
Mr Klompy what a bummer but you really got in there and nailed it.
Halo
84 K100RS 0014803
93 FZR1000 EXUP
23Back to top Go down   ugly photos Empty Re: ugly photos Thu Nov 15, 2012 4:45 am
charlie99 wrote:just a reminder klompy .. as inge i think suggested
Filler cap........ Check
expansion tank Check ( yuck)
indicator tube Check ( filthy )
Discovered something interesting....ran, cleaned and bled the system ( took hours with tank precariously balanced to the left) had rad cap off watched the fluid flow when thermostat opened saw and heard the fan go on but my temp gauge did not move off cold?? so I earthed the wire out and it went off scale high,,,,so the gauge works ok perhaps the sender unit is kaput ( yet the fan came on but no high temp light????) I guess I have to buy a replacement sender unit...here is where it gets strange my ole sender has a circular post you clip the wire to but the replacements I have found have a twin pin connection...what is the go there???
http://www.motorworks.co.uk/bmw/prodimages/lg/ELA59197.jpg
http://www.motobins.co.uk/library/74130.jpg
HELP cause mine looks like this
ugly photos Water-11
24Back to top Go down   ugly photos Empty Re: ugly photos Thu Nov 15, 2012 4:57 am
The pictures from Motorworks/Motobins shows the sensor for the jetronic/fan/warning light, for the temp gauge it is a sensor like the one in your first picture.
Have a look here.
25Back to top Go down   ugly photos Empty Re: ugly photos Thu Nov 15, 2012 5:00 am
its all smoke amd mirrors mate ...!
the temp sensor that your looking at is the temp guage only ....an indicator, an auxilary to function thingo only ....and after the cooling system , before it enters the motor propper.
the actual dual element temp sensor for engine management and fan function is located in the water stub ...straight off the engine housing behind the radiator and a little right of the throttle bodies ..(so perfectly likely that it would get over 100 deg c right there , before it enters the radiator etc and then the thermostat some where along the way a bit further )
beware of the threads and mating connections of this little blighter ....brass and aluminium dont co-exist well together....
but by the sounds of it, all is well so far. just make that connection to the sensor again ...clean up the electrical connections both between the bottom of the water pump and up through the wiring harness to the guage ...most recover ok .
26Back to top Go down   ugly photos Empty Re: ugly photos Thu Nov 15, 2012 5:06 am
Thanks Charlie...neglected to mention that sensor may have been treated inhumanely and not wrapped in cotton wool on removal......mmmmmm,,,may have dropped it a little bit....and found the right one....bloody thing never worked real well....dear mr moto bin/works .......
ugly photos Water_10
27Back to top Go down   ugly photos Empty Re: ugly photos Thu Nov 15, 2012 5:51 am
oh ! drop event huh ?...giggles
yeah seems doofus charlie put his blooming oil presure sensor and temp sensor (attached to water pump housing ) through the ultrasonic cleaner ...right royal leak from oil pump sensor after wards ( what was i thinking )
cheers !...it does get better grin !
28Back to top Go down   ugly photos Empty Re: ugly photos Thu Nov 15, 2012 5:55 am
Its true then...misery does love company......I think that perhaps I am on the BMW parts christmas card list already.....
Cool so another question from left field......does the red overheat light ever come on when it is not high temp.....i.e. how do you know it is going to work...other lights come on with ignition on but my oh does not....or is this all normal get back in your box klompy ..... Question
29Back to top Go down   ugly photos Empty Re: ugly photos Thu Nov 15, 2012 6:06 am
Think the bike is still sucking air like a lung fish. Gonna get some start ya bastard to check.
If it all turns good, can I come use your vvaaccuumm gauges?
Still not running good.
Probably something Alby did in the carpark.
Never trust a pub carpark repair person. (Didn't he fix your perfectly running RS while you were there? Oil in the water eh? Coincidence? Check the share price of Motoworks after that weekend.)
Or the people who laugh around them. cough (charlie)
So I had an air leak.
Bet it was less of a leak than some of the folks after pints (600ml) beers for 6 hours.
So can I come use your suck bits?
kthxbai
rossco
30Back to top Go down   ugly photos Empty Re: ugly photos Thu Nov 15, 2012 6:18 am
sure Klompies motel and garage are always open.....tomorrow after 12 I can be home......call me when etc ....remember I am on a top secret establishment just google map it...lol
see you when you are free...
31Back to top Go down   ugly photos Empty Re: ugly photos Thu Nov 15, 2012 6:25 am
good luck you guys .....i can see its going to be a fun place to be ....cheers !
32Back to top Go down   ugly photos Empty Re: ugly photos Thu Nov 15, 2012 4:27 pm
Alby's tune up on the orange in the pub car park was perfect...no problems. But I don't drink alcohol....maybe that could be the reason for your misfortunes.
33Back to top Go down   ugly photos Empty Re: ugly photos Thu Nov 15, 2012 5:34 pm
Klompy the grey brick wrote:sure Klompies motel and garage are always open.....
So I get to sleep in the motel while you fix my bike?
What service.
Probably not available till Sinday Sunday. Not all of us have cushy government jobs.
rossco
34Back to top Go down   ugly photos Empty Re: ugly photos Thu Nov 15, 2012 6:32 pm
oh you do have a way with words young Rossco...you pay my wages now and I want a pay rise to compensate for the cost of BMW parts.
Just give me a call , of course if the weather is really atrocious it will be perfect for maintenance in the "mancave"...I have the TV and fridge and a selection but not so good for riding to beautiful sunny Richmond.
35Back to top Go down   ugly photos Empty Re: ugly photos Fri Nov 16, 2012 4:58 pm
Just as a point of info Mercedes Benz have a cooling system de-oiling detergent which is the go for cleaning out cooling systems that have had the oil emulsion in them.
