1 TB adjustment (or not) Sun Oct 14, 2012 10:52 am
ReneZ
Team, have a question/idea for discussion. We are all (mostly) aware of the situation with the throttle body linking screws; not to be touched etc. However sometimes a PO seem to have gotten to them anyway (always a Previous Owner of course ).
From the factory the original setting is done with a flow bench, which is understood to be more precise than with vacuum equipment on the bike. I once tried to make a box where I could fit the TB's on with some old stubbs to see if I could get them better adjusted off the bike with a shop vac at the end. This didn't work (for me) as somehow the air flow wasn't even through the bodies. After too much local recipe (I'll leave that to your imagination) I thought what if we were to use an anemo meter to measure the air flow through the TB's individually to adjust/check them? Something like THIS
We wouldn't be interested in absolute, genuine measurements, so calibration etc is not required. Repeatability however is, as you need to measure each TB individually. I'm certain one could quickly come up with an adaptor between the tool and the TB. With an old (or current) vacuum cleaner at the other end you should then be able to do a proper adjustment or check.
Any ideas/comments/faults/remarks/critisism on the above??
Greetings from
Rene
BMW K100 - 1985 (0030029) Scotland
