Go to page : Previous  1, 2
51Back to top Go down   Rear shock mount stud removal - Page 2 Empty Re: Rear shock mount stud removal Sun Dec 02, 2012 6:40 pm
JR_K100RS
One for me too please !
Ta Ainsjac
JR
Melbourne Australia
52Back to top Go down   Rear shock mount stud removal - Page 2 Empty Re: Rear shock mount stud removal Sun Dec 02, 2012 7:00 pm
[quote="JR_K100RS"]One for me too please !
Ta Ainsjac
Looks like a good excuse to go to Dubbo for a Pub car park maintenance day???
See you there ...
Last edited by Klompy the grey brick on Mon Dec 03, 2012 12:27 am; edited 2 times in total
KKlompy Rear shock mount stud removal - Page 2 2854237993
Rear shock mount stud removal - Page 2 Au-log10
53Back to top Go down   Rear shock mount stud removal - Page 2 Empty Re: Rear shock mount stud removal Mon Dec 03, 2012 2:35 am
col
col
stan
i am for 1
klompy
let me know if your going thru if not working will tag along
1991 k100lt "the enterprise"
54Back to top Go down   Rear shock mount stud removal - Page 2 Empty Re: Rear shock mount stud removal Mon Dec 03, 2012 2:38 am
Don't you guys keep spares?
Just curious. Is it a Southerner thing? Twisted Evil
55Back to top Go down   Rear shock mount stud removal - Page 2 Empty Re: Rear shock mount stud removal Mon Dec 03, 2012 2:48 am
col
col
we will just use yours if we need one should hpoefully get another at least 22 years or mor more out of the new ones they high tensile after all and the farmers fence worked well on the yellow peril ifn we do get stuck
56Back to top Go down   Rear shock mount stud removal - Page 2 Empty Re: Rear shock mount stud removal Mon Dec 03, 2012 3:36 am
Baaa
I'm a sheep. Follow the herd.
Yes please Stan. 1
When is the fitting day? Dubbo you say?
I hear it is nice ride up the Putty road to Denman then across to Dunedoo and Dubbo Smile
57Back to top Go down   Rear shock mount stud removal - Page 2 Empty Re: Rear shock mount stud removal Thu Sep 23, 2021 4:33 am
bmwk100rs
bmwk100rs
RicK G wrote:The thread is 12mm x 1.5 pitch.
The red one is the correct one
Rear shock mount stud removal - Page 2 Bolt_h10
Sorry for reviving the old post, but this is good information. RicK G, Is the M12-1.5 stud coarse or fine thread?
Rear shock mount stud removal - Page 2 Coarse10
58Back to top Go down   Rear shock mount stud removal - Page 2 Empty Re: Rear shock mount stud removal Thu Sep 23, 2021 5:46 am
1.5mm pitch is standard pitch for an M12. This might be useful:-
https://fullerfasteners.com/tech/basic-metric-thread-chart-m1-m100-2/
59Back to top Go down   Rear shock mount stud removal - Page 2 Empty Re: Rear shock mount stud removal Sun Sep 26, 2021 4:22 am
bmwk100rs
bmwk100rs
Dai wrote:1.5mm pitch is standard pitch for an M12. This might be useful:-
In the U.S., M12-1.5 coarse thread is NOT the standard pitch though.
60Back to top Go down   Rear shock mount stud removal - Page 2 Empty Re: Rear shock mount stud removal Sun Sep 26, 2021 11:28 am
bmwk100rs wrote:In the U.S., M12-1.5 coarse thread is NOT the standard pitch though.
What's your source for that assertion, rs? Can you provide the link?
61Back to top Go down   Rear shock mount stud removal - Page 2 Empty Re: Rear shock mount stud removal Sun Sep 26, 2021 2:55 pm
bmwk100rs
bmwk100rs
62Back to top Go down   Rear shock mount stud removal - Page 2 Empty Re: Rear shock mount stud removal Sun Sep 26, 2021 7:47 pm
bmwk100rs wrote:However, let me know if you have a better source in the U.S.
Suzi Q should advise you because machining is in her genes. Smile In the interim, there's this.
Use what you can find. Fine thread bolts have greater threads per inch than coarse thread bolts; for our purpose, it doesn't matter who-calls-which-what, or which you use if you aren't a stunter leaping ramps regularly. If the hole and bolt have the same thread pitch, they're likely to fit together.
If you're needing to tap the hole, you choose the thread pitch and diameter you want to use and tap accordingly. If you want to use an 8.8 grade bolt that's 12mm width, use the pitch that's available.
When my shock's stud bent, I extracted it. This was in 2013. Rick G had already given his recommendation in the thread. After realizing he drag-raced, had a beard and could write intelligibly, like the instruction-following drone I am, I got one and used it because it fit the threads in the hole and because I'd rather ride than ruminate. I had no trouble finding an appropriate bolt at Ace Hardware to fit the hole.
What you really want to spend time doing—instead of going further down the rabbit hole you've entered—is fabricating one of these once you've mounted the replacement stud.
63Back to top Go down   Rear shock mount stud removal - Page 2 Empty Rear Shock Mount Stud thread pitch Fri Apr 19, 2024 4:13 am
redrockmania
redrockmania
After a thorough web search including our forum, there are a range of different claims about the diameter and thread pitch of the rear shock mount stud.
I've just measured mine with vernier's and a thread pitch gauge. Correct diameter is 12mm (not 10mm as some have posted). Correct thread pitch is 1.75 coarse (not 1.5 as some have posted).
Last edited by redrockmania on Sat Apr 20, 2024 6:42 pm; edited 1 time in total (Reason for editing : correction of my earlier thread pitch references in this post)
64Back to top Go down   Rear shock mount stud removal - Page 2 Empty Re: Rear shock mount stud removal Sat Apr 20, 2024 5:18 pm
As a person who's suffered the ignominious shockie stud breakage whilst riding two-up (while overtaking a car) Down Undah, I know full-well what a hassle it is, so I carry a spare, and two nuts with which to unscrew the broken one if it's got anything sticking out....Thanks to Rick G and Marg we had the offer of a comfy bed, a trailer ride, dinner, and a pleasant evening with friends, home the next day, instead.
Re-reading the entire thread I see that one person mentioned 10mm and was corrected, then said "oops".
I'm fairly certain the general membership know it's a 12mm stud, and that .05 thing is surely a typo.
Here's a piccie of the two (OEM stud part numbers as spares) lengths with a thread pitch gauge doing its job.
Rear shock mount stud removal - Page 2 20240411
