1Back to top Go down   K1100 wireloom questions Empty K1100 wireloom questions Mon Apr 22, 2024 12:15 pm
SunnyPerth
SunnyPerth
K1100 wireloom questions Img_6810
K1100 wireloom questions Img_6811
K1100 wireloom questions Img_6710Hi Team, question(s)  the purists and wisdom people here..
Making steadily progress with the ground up resto of my 93 K1100lt - see first image attached. Now ready to start putting back in the wire loom(s)
Have two questions there
1) while cleaning / checking the ‘lower’ part of the loom, I noticed a few of what looks like on purpose made pin holes (drain holes ?) in the wire sleeve going to the ignition control unit. Looks the 4 holes are in there with an offset from each other and potentially on the lowest point of the loom.
Is that correct, are they there intentionally?
(Or should I check if this is heat / age related and check the wires within)
2) besides the check/upgrade of the earth cables and putting in extra relay for headlight, should I do any other mods to electric system ?
Cheers, Y
2Back to top Go down   K1100 wireloom questions Empty Re: K1100 wireloom questions Mon Apr 22, 2024 2:53 pm
Mmm. Brain brings forth a long-forgotten memory of seeing those holes before. I guess it is possible that they are a 'recall modification' because they are definately too rough to be ex-factory.
Any upgrades? Chuck a 50amp alternator in there if you can find one. That will give you the headroom for anything you want to add later (lights, heated clothing, etc.). Also I'd add a Hella charging socket on the top of the coil cover (does the K1100 already have one?). A USB socket up in the fairing would be a good idea too.
3Back to top Go down   K1100 wireloom questions Empty Re: K1100 wireloom questions Mon Apr 22, 2024 3:01 pm
SunnyPerth
SunnyPerth
Thx Dai ! Good idea about the usb socket. I’m
Probably ok in winter time here, perth Australia, if anything I should look for portable aircon. Wink
But good idea about a 50a alternator., as extra light is definitely on the radar.
And I’ll need to check where the wires for the radio and speakers went…
4Back to top Go down   K1100 wireloom questions Empty Re: K1100 wireloom questions Mon Apr 22, 2024 5:27 pm
As I just have changed my frame, I could inspect the loom and I can affirm that there were no such holes.
About the USB socket, beware: some are continuously pumping energy and will empty you battery in a few weeks.
Do not plug this socket directly on the battery, but on a wire powered after the main key contact.
That fills our fairest day.
5Back to top Go down   K1100 wireloom questions Empty Re: K1100 wireloom questions Tue Apr 23, 2024 7:54 am
SunnyPerth
SunnyPerth
Thx JBT, definitely would wire up the USB charger on a switched (ignition) line. (Likely adding a relay, that I might hav to put in for the radio anyway)
Still not completely sure about the holes in the wire sheeting - but will remove / open a little to check out the wires inside ..
Thx mate,
Y
