1Back to top Go down   Coupla questions on K1100 forks Empty Coupla questions on K1100 forks Sat Feb 23, 2019 9:55 pm
I'm sorta thinking of fitting a set of K1100 forks mostly for the uprated braking. I'm not a fan of that two-part mudguard, so the question is: has anyone ever fitted or tried to fit the K100 style mudguard to K1100 forks? Ignoring the fork brace, do they fit? A welder and some 3mm steel plate will sort out the fork brace.
2Back to top Go down   Coupla questions on K1100 forks Empty Re: Coupla questions on K1100 forks Sun Feb 24, 2019 12:25 am
I put a 2 piece guard on my K100 but not the other way but with some imagination and a welder I don't think it would be difficult. A small bracket that fixes to the brace plate would be all it should take. You could use the 2 piece from an RS the back section is the same as the K75 guards or cut the LT rear section down to match.
I gotta admit the LT guard sure is fugly.
3Back to top Go down   Coupla questions on K1100 forks Empty Re: Coupla questions on K1100 forks Sun Feb 24, 2019 7:34 am
Thanks Rick. It looks like it's doable then.
4Back to top Go down   Coupla questions on K1100 forks Empty Re: Coupla questions on K1100 forks Sun Feb 24, 2019 12:13 pm
I reckon the four inward facing fork brace tabs on the Marzocchi (or other K11) fork legs would be more in the way of fitting an early one piece mudguard, rather than just a convenient place to fit your own fabbed up brace that doesn't intrude on the space needed for the early muddie.
I don't have an early fork to compare to in my shed or garage at the mo', but deduce this from squizzing at ETK.
To clarify,  when you write K100 mudguard...mine are two piece, is the assumption made on your part that all K100 fenders are one piece?
5Back to top Go down   Coupla questions on K1100 forks Empty Re: Coupla questions on K1100 forks Sun Feb 24, 2019 1:15 pm
The K11 fork braces have the brake line splitter in them so you'd need to figure out what to do with piping the 4V brake calipers too.
FYI: The K1100LT fork brace has more tire clearance than the RS one because the LT front tire is 24.93" in diameter while the RS front is 23.61".  You can't run an LT front wheel with an RS fork brace without doing some minor mods.
6Back to top Go down   Coupla questions on K1100 forks Empty Re: Coupla questions on K1100 forks Sun Feb 24, 2019 4:40 pm
@TWB: yes, as in one-piece mudguard, except for the RS. I was a bit worried about those mounts when I started looking at things.
@ Duck: Brakelines are never a problem as I make my own. LFB's brakeline splitter is an Aprilia item and is mounted on the fork brace. The brace itself is two pieces of 1.5mm plate ('coz I didn't have a piece of 3mm at the time) bolted to a pair of Tarozzi fork "grips" (there's gotta be a proper name for them but I have no idea what it is... Very Happy ). It's not quite as ugly as it sounds!
7Back to top Go down   Coupla questions on K1100 forks Empty Re: Coupla questions on K1100 forks Sun Feb 24, 2019 10:43 pm
Dai wrote:The brace itself is two pieces of 1.5mm plate ('coz I didn't have a piece of 3mm at the time) bolted to a pair of Tarozzi fork "grips" (there's gotta be a proper name for them but I have no idea what it is... Very Happy ).
Sort of like this? They're called le cose che accarezzano i tubi. Laughing
Coupla questions on K1100 forks Screen48
8Back to top Go down   Coupla questions on K1100 forks Empty Re: Coupla questions on K1100 forks Mon Feb 25, 2019 7:47 am
Loosely translated as 'tube chompers'. Very Happy
9Back to top Go down   Coupla questions on K1100 forks Empty Re: Coupla questions on K1100 forks Mon Feb 25, 2019 7:52 am
When I worked for Honda Australia we would knock back warranty claims for leaking fork seals if those things were fitted.
I did put one of them on my Z1300 Kawasaki and found the seals leaked, when I removed them no more leaks
10Back to top Go down   Coupla questions on K1100 forks Empty Re: Coupla questions on K1100 forks Mon Feb 25, 2019 1:06 pm
I've had no problems on Guzzis or the brick with Tarozzi braces. Sounds like the problem may have stemmed from 'thin' walled sliders that were being distorted by the brace. Or possibly a badly-machined tube chomper, I suppose.
11Back to top Go down   Coupla questions on K1100 forks Empty Re: Coupla questions on K1100 forks Sat Mar 09, 2019 11:29 am
tinyspuds
tinyspuds
Dai,
I inherited a 1 piece fender with my ‘85 RT which I assume is original from the tele forks. If you need one to experiment with, its yours for the asking. Will post pic if you’re interested.
Stu
12Back to top Go down   Coupla questions on K1100 forks Empty Re: Coupla questions on K1100 forks Sat Mar 09, 2019 3:39 pm
I've given the idea up, Stu. I wanted better braking but discovered last Tuesday that EBC HH pads on cast iron discs pushed by a 13mm m/c is enough to squeal the tyre on a dry road. That'll do me, Tommy!
13Back to top Go down   Coupla questions on K1100 forks Empty Re: Coupla questions on K1100 forks Sat Mar 09, 2019 4:04 pm
Woodie
Woodie
The sound effects are missing but the same set up will easily and even more quickly lock up the front tire in the wet Dai.   Very Happy  And yes, this is fully based on my own experience.  I seem to recall that Mr. Romestant mentioned the main benefit of the 20mm MC was that it offered a broader range of control.
Coupla questions on K1100 forks Logo2111
1985 K100RT  52667
1990 K75RT 6018570 (project)
14Back to top Go down   Coupla questions on K1100 forks Empty Re: Coupla questions on K1100 forks Mon Mar 11, 2019 6:21 pm
Snod Blatter
Snod Blatter
Dai wrote:I've given the idea up, Stu. I wanted better braking but discovered last Tuesday that EBC HH pads on cast iron discs pushed by a 13mm m/c is enough to squeal the tyre on a dry road. That'll do me, Tommy!
With these cast discs I've honestly never had more than gentle retardation with Ferodo Platinums and now organic EBCs. Clearly sintered is the way to go, but what if the whole lot rusts together when left in the rain..??
I think I got mine to skip along over some pebbles once. Downhill. When a car suddenly wanted to come the other way up a narrow lane and panic braking ensued.
15Back to top Go down   Coupla questions on K1100 forks Empty Re: Coupla questions on K1100 forks Tue Mar 12, 2019 9:06 am
Ah.... well... I don't have a standard setup. My m/c is a 13mm jobbie from a Laverda Formula 750. It does rust. Add salt to the mix and leave overnight. Now try getting the bike off the mainstand....
Smacking the calipers with a big rubber mallet solves the problem Very Happy Very Happy Coupla questions on K1100 forks 44271
