1Back to top Go down   2 questions about K11 Empty 2 questions about K11 Wed 10 Oct 2012, 11:34
DeRodster
DeRodster
re my 1992 K1100lt.
One silly and one maybe not,
well maybe not so silly but I don't have enough experience with the machine to know the answer .
First the "silly" one.....how do I know the heated grips are heated ? or even fitted
and
if my hazards are not working does it mean the relay is kaput or was never fitted in the first place.
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
2Back to top Go down   2 questions about K11 Empty Re: 2 questions about K11 Wed 10 Oct 2012, 11:48
If you got heated grips, you would also have a 3 position switch at the handlebar cover.
If your hazards don`t function, the problem could be the switch or the related wiring.
The connector you find under the tank, the switch connects to ground.
