1Back to top Go down   Front suspension Empty Front suspension Mon Oct 01, 2012 7:50 am
BillOwens
BillOwens
Just had our club inspector pass bike for classic rego
He felt the front suspension seemed soft, ie it would dive under front braking
Can it be stiffened, it certainly is softer than the Ducati
http://www.wdmoc.com
2Back to top Go down   Front suspension Empty Re: Front suspension Mon Oct 01, 2012 8:28 am
Hello Bill,
If you do a search you'll find plenty of discussion on this topic.
Yes, the front suspension is a bit soft or perhaps better known as compliant.
First thing to do is change the fork oil. It may have been in there since Moses played fullback for Jerusalem.
Then work from there...progressive springs etc.
It's a good idea to put your bike model and year in your signature.
Sean.
3Back to top Go down   Front suspension Empty Re: Front suspension Mon Oct 01, 2012 8:38 am
They are very touchy on the grade of oil some use 5SAE and 7.5 or 10 and some even mix grades to their liking but anything over 10 weight usually rattles the bones a bit.
4Back to top Go down   Front suspension Empty Re: Front suspension Mon Oct 01, 2012 8:47 am
+1 what the guys say Bill.
When I got my LT the fork dive was waaay to much for my liking. I replaced the fork oil with 10w (IIRC) and the difference meant that I could put all thoughts of spring replacement aside.
Here's a recent thread on the subject with some handy tips.
Front suspension Ir-log1188....May contain nuts!Front suspension Ir-log11
K75RTP - 1994
5Back to top Go down   Front suspension Empty Re: Front suspension Mon Oct 01, 2012 12:03 pm
I've retrofitted the K75S 'S' front forks to my K100RS. The difference in feel (and reduced suspension travel) is amazing; they are much firmer than the typical long travel front suspension. The 'S' forks use only 280cc of fork oil and the weight I decided upon after trying all weights is 5W. I weigh less than 85kg dressed for the sunshine in a sudden downpour.
Using 10 or 15W oil can help but often it's a matter of not enough fluid in the forks in the first place. I recommend a flush and refill with the correct level spec to see how much it changes. Barring that, some Progressive springs or replacement with the OEM might make a difference.
6Back to top Go down   Front suspension Empty Front suspension Wed Oct 03, 2012 6:27 am
BillOwens
BillOwens
Will do a drain and refill this weekend, is 360 ml per fork correct
Is there an easy way of getting the new oil in?
Should I use my compressor to blow all the old stuff out?
1984 BMW K100 RS black,90,000km, 1982 Ducati Pantah 600SL 2,000km since restoration, 1949 Velocette Mac 350, undergoing restoration
7Back to top Go down   Front suspension Empty Re: Front suspension Wed Oct 03, 2012 7:10 am
Use a bit of aluminium foil to keep the oil away from the discs and remove the top bung then the bottom bung as there is often pressure in there. You will need a gas mask , it will stink.
I use a big 100ml syringe to put the oil in the top and measure it, got it from a vet.
8Back to top Go down   Front suspension Empty Re: Front suspension Wed Oct 03, 2012 7:10 am
Not sure about the compressor, but use a horse syringe. Takes a few to get it all in, but you won't spill any.
I tried a pvc hose and funnel. If you have a really small diameter hose it is ok, but the air obviously needs to get out.
9Back to top Go down   Front suspension Empty Re: Front suspension Wed Oct 03, 2012 8:49 am
bill there is usually enough suction to work the oil out the bleeder holes at the bottom with a few pumps of the front end on the handle bars .
our good friend inge posted a fantastcic tool for keeping the oil from blowing all over the forks disks et all ... durring the empty process
its a cut up bottle ...hope i can find the pic again (might have to use the search feature )
10Back to top Go down   Front suspension Empty Re: Front suspension Wed Oct 03, 2012 9:00 am
It was in a thread where RT was changing his fork oil.
And did find one of the drain holes clogged,...or was the leg empty......?
Front suspension Drener10
Front suspension Drener11
Last edited by Inge K. on Wed Oct 03, 2012 9:06 am; edited 1 time in total (Reason for editing : Adding pictures.)
11Back to top Go down   Front suspension Empty Re: Front suspension Wed Oct 03, 2012 9:10 am
12Back to top Go down   Front suspension Empty Re: Front suspension Wed Oct 03, 2012 12:57 pm
Motorandy123
Motorandy123
I recently installed some K100 springs that I cut down by 2" to get the appropriate
stiffness. According to Racetech the stockers are 0.72 kg/mm and 0.80 to 0.85 would
be best. I threw in some lightly thicker oil (10 w) to bring the rebound back and she
should be all set!
13Back to top Go down   Front suspension Empty Fork oil change Sun Oct 07, 2012 8:14 am
BillOwens
BillOwens
Drained both forks, still oil but watery and probably 200ml per side
Put 360ml sae10 per side. No leaks yet, rides well
Also got 2 nd hand mount for the broken one that came with it
14Back to top Go down   Front suspension Empty Re: Front suspension Sun Oct 07, 2012 8:35 am
good work bill ...amazing what fresh oil does for the ride
happy times ol mate !
15Back to top Go down   Front suspension Empty Re: Front suspension Sun Oct 07, 2012 9:49 am
Bill if your seals have been leaking (I am not sure if they were) check the radiator as the oil gets there and collects dust and clogs the fins on the outside.
16Back to top Go down   Front suspension Empty Re: Front suspension Sun Oct 07, 2012 9:59 am
Good advice,......as always.
17Back to top Go down   Front suspension Empty Front forks Mon Oct 08, 2012 6:14 am
BillOwens
BillOwens
Thanks for the advice Rick, will check asap
