Go to page : Previous  1, 2
51Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Mon Sep 16, 2013 7:18 pm
ausbrick
Some old pics of my café currently getting a paint job, would love to ride it around Tassie, thanks for the info on the fairing bit pricey for me I'll more likely make something up.Cheers Mick
Too good to scrap - Page 2 PA130128-Copy_zps43d93391
 Too good to scrap - Page 2 PA130123-Copy_zps2555f237
Too good to scrap - Page 2 PA130124-Copy_zpsec5cc908
52Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Mon Sep 16, 2013 8:23 pm
bushyintas
bushyintas
Ausbrick,
Fairing link was only a guide,
I bought the fairing of good old e-bay for $65 inc postage.
You just have to keep an eye out for these things, the only trouble is that you sometimes buy things on a whim then when they arrive you think ''why did I buy this?''
Your k1100, wheels look the part, the front tyre looks to me to be wider than the standard 100-90-18 on my k100, are they the right size for the 1100's.
You need to fill in the gap at the rear of you seat to make the lines smoother, other than that I like it, the front looks pretty mean, In a good way.
Last edited by bushyintas on Mon Sep 16, 2013 8:30 pm; edited 1 time in total (Reason for editing : more info)
53Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Tue Sep 17, 2013 1:12 am
MikeP
MikeP
bushyintas wrote:Your k1100, wheels look the part, the front tyre looks to me to be wider than the standard 100-90-18 on my k100, are they the right size for the 1100's.
I think they're K1200RS or R1150 wheels.
I see that the wheel-mounted rear disc is carried over as is the rear caliper and the front requires the calipers to be mounted on an adaptor of some kind.
I'm interested because I like that wheel pattern and fancy doing something similar to my "K1100R" project (one day when finance permits).
1992 K1
54Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Tue Sep 17, 2013 11:18 am
ausbrick
ausbrick
Hey guys , The rear section has been fibre glassed and moulded into one and is ready for  painting. the wheels are off an r 1150 and front is a 130-17tyre, got them on fleabay   .The front brakes required a plate to be made for the caliper to use the bigger discs  and well worth as it pulls up real hard  also had to change the bearings as they have different axle dia and machine up new spacers to suit the forks .Rear disc has now been changed back to the standard k as the rear wheel had to be offset too far to make the 1150   fit ,pity as it braked really well and didn't over heat like the k set up if you give it a long hard workout . The rear r1150 wheel has an greater offset than the k1200 wheel but has the lugs on it to mount the disc, they do not clear the  k caliper . I have now machined these off and it works with the k disc setup well .I would go with a k1200 rear wheel[ less messing around ]and the offset is less .I run one on my other k1100 tourer with a 170 tyre it misses the swingarm by 3-4 mm but has never caused any problems, thought it might rub but its  wide low profile does not seem to flex at all , they usually run a 160 that would help. All in all its a hoot to ride and cost very little to string together . don't forget this is a k1100 with para rear end these mods are not as easily suited to k100.Cheers  A B
55Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Fri Oct 11, 2013 12:31 pm
bushyintas
bushyintas
I went to take her for a run today, low battery, I know I should have charged it before trying to start,
thought it might just kick, but no..... welded the contacts on starter relay..... BUGGER !
I will pull apart and see if relay can be salvaged.
The advice is plainly here on this forum,
but the weather was nice and clear, the temptation large, patience at the time nil, just wanted to
ride, final outcome, no ride, more work and expense. I guess I'm not the first and definitely not the last
it's like ''just tighten that nut a little more", you all know how that story ends.
annoyed at myself
Bushy
56Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Fri Oct 11, 2013 12:42 pm
Some of the Kawasakis have a soleniod type relay which is far less prone to welding shut and would fit into the same space.
The relay on the K75 welded a couple of times and I just dressed the contacts and all is still good, it's worth a try.
57Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Tue Oct 29, 2013 8:52 am
bushyintas
bushyintas
All fixed ,
turned out to be the load shed relay
not the starter relay as thought.
Just waiting for some warmer drier weather so the final paint can be applied.
58Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Tue Oct 29, 2013 9:55 am
good find bushy
happy riding mate
59Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Fri Nov 08, 2013 5:08 pm
snowbeard
snowbeard
looks cool! I particularly like where the instruments ended up, been wanting to arrange that better on mine at some point...  any info on the mount you made up?
60Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Fri Nov 08, 2013 7:24 pm
bushyintas
bushyintas
Snowbeard,
the mount for the instrument cluster is a flat plate mounted on rubber mounts similar to the ones for the battery tray, using the existing threaded holes on the tripple tree. then an angled bracket manufactured to suit the bottom of the cluster rectangular hole for the plug set up and bent to desired angle approx 120*. bolt the cluster to the desired height onto the flat plate.
I'll post a photo when the weather clears.
regards Bushy
61Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Sat Nov 09, 2013 5:36 pm
bushyintas
bushyintas
photos of instrument cluster mount...
Too good to scrap - Page 2 0111
Too good to scrap - Page 2 0210
Too good to scrap - Page 2 0310
62Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Sat Nov 09, 2013 8:15 pm
done well there bushy    ^5s
63Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Sun Nov 10, 2013 12:54 pm
snowbeard
snowbeard
nicely done there mate! I wonder if I might be able to manage that effect with a couple of brackets that simply drop the existing mounting plate lower! Thanks for the extra pictures!! Big thumb
64Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Sun Nov 10, 2013 5:01 pm
bushyintas
bushyintas
I recon you could,
 I needed to attach a head light mount low along with the fairing, so this was the easiest way.
65Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Tue Nov 12, 2013 11:41 am
snowbeard
snowbeard
I got a few minutes spare today and managed some brackets! only had some light aluminum but used two strips just in case. We'll see how it does in the long-term, but it dropped it just where I wanted it! Thanks for the beta! Too good to scrap - Page 2 22936
Too good to scrap - Page 2 Bracket_zps65603140
Too good to scrap - Page 2 Newdash_zpsc61220f0
66Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Tue Nov 12, 2013 3:24 pm
When you go to naked and haven't got the OEM headlight/gauges suround the gauges sure look better when they are dropped by 3 inches or so.
67Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Fri Jan 03, 2014 10:59 am
bushyintas
bushyintas
Front end finally finished, just paint tank and a few odd jobs left.
Too good to scrap - Page 2 13887012
Too good to scrap - Page 2 13887013
Too good to scrap - Page 2 13887014
Too good to scrap - Page 2 13887015
Happy New Year
Bushy
Bushy
k100 RT 1988 #0095723
K100 RT 1984 into Custom Single seat.  #0024503
68Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Fri Jan 03, 2014 11:01 am
Looking good mate, looking good.
69Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Fri Jan 03, 2014 12:46 pm
noice bushy very noice
70Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Sat Jan 04, 2014 3:00 am
Lookin' good Bushy, I like your colour choice.
Too good to scrap - Page 2 Ir-log1188....May contain nuts!Too good to scrap - Page 2 Ir-log11
K75RTP - 1994
71Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Sat Jan 04, 2014 7:07 am
k-rider
k-rider
Looks very nice, love the color it suits the bike well Big thumb
72Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Sat Jan 11, 2014 11:28 am
bushyintas
bushyintas
Update...
Tank sprayed and back on,
rear guard off for final coat,
nearly there...
Too good to scrap - Page 2 Img_2010
Too good to scrap - Page 2 Img_2011
Too good to scrap - Page 2 Img_2012
Bushy
Bushy
73Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Sat Jan 11, 2014 11:31 am
Looking good, Bushy  Too good to scrap - Page 2 112350 .
74Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Sat Jan 11, 2014 6:40 pm
xpc316e
xpc316e
You know what, that is a really mean-looking bike.  I would quite happily be seen riding that lovely machine.
75Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Sat Jan 11, 2014 7:00 pm
Very nice Bushy.
Great colour.
Do you have a very very very small person you are going to put on the back?
Solo seat with handles  Rolling Eyes
76Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Sat Jan 11, 2014 7:46 pm
bushyintas
bushyintas
Just my imaginary friend.....
Nah that's the '84 seat with the center cut out and re joined wit a mig, lucky it was a metal base, plastic doesn't like my welder, I've melted things then said''should have taken that off before I...''. Oh well.
thanks xpc316e and all the comments received, all good fun,
hope to SI (special interest) register in October when it turns 30 yrs, cheaper rego, can ride 52 times a year, only draw back is you have to keep a log book.
Bushy
77Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Sat Jan 11, 2014 10:44 pm
k-rider
k-rider
52 times a year isnt much, any limit to the distance riden
k-rider
ohh, btw, how much cheaper is the si
78Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Sun Jan 12, 2014 3:13 pm
bushyintas
bushyintas
I think its aprox half, no limit on Km, just times as in days, you can have 52 individual ride days or take the 52 all in one hit, not limited to state can travel anywhere.
Only SI this one as already have 88 RT on full rego.
Bushy
Bushy
79Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Wed Jan 15, 2014 8:59 pm
bushyintas
bushyintas
I think I'm finished....but are we ever really.
the latest pics taken today, hot day in Tassie 29 deg C. almost unbearable.
Too good to scrap - Page 2 Img_2013
Too good to scrap - Page 2 Img_2014
Too good to scrap - Page 2 Img_2015
Too good to scrap - Page 2 Img_2016
Too good to scrap - Page 2 Img_2017
Too good to scrap - Page 2 Img_2018
Too good to scrap - Page 2 Img_2019
New tires to be fitted closer to rego.
What do you think....?
Bushy
80Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Wed Jan 15, 2014 9:30 pm
Dude, let the purists bitch. That is one fine looking bike.
What a fantastic result.
Think it needs to visit the north island so we can look first hand.
I know you crave my approval, so I approve.
Criticism. Ditch the bags.
81Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Wed Jan 15, 2014 9:33 pm
bushyintas wrote:
New tires to be fitted closer to rego. What do you think....?
I really like it.
You were able to 'personalize' your bike when keeping most of the aesthetic/design/features of the original K100. Fantastic job and ... I like the color too.
I agree with Rossko. The bags don't fit the bike.
CF
Too good to scrap - Page 2 Frog15Too good to scrap - Page 2 Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
82Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Wed Jan 15, 2014 9:50 pm
I really like it.
CF
Mate, if you come visit the north island, you can put the bags on.
Guessing it is not a long distance tourer.
Just take me off before you let us take photos  Very Happy
83Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Wed Jan 15, 2014 10:14 pm
bushyintas
bushyintas
Bags are so I can ''ride to work'',
Any excuse to ride I'll take.
Bushy
84Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Thu Jan 16, 2014 7:56 am
Your bike has really evolved into one great looking one. We need more orange bikes.
85Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Thu Jan 16, 2014 11:05 am
bushyintas
bushyintas
Before....
Too good to scrap - Page 2 2328ak10
Too good to scrap - Page 2 5787gi10
Too good to scrap - Page 2 33459c10
Bushy
86Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Thu Jan 30, 2014 8:30 pm
bushyintas
bushyintas
found this pic while browsing the net today.
Too good to scrap - Page 2 K1100_11
Any ideas on origin, looks shorter and lower than standard.
Stated as K1100 Shortback.
I like the look.
Bushy
87Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Thu Jan 30, 2014 9:20 pm
that 1100 reminds me of zonfields bike but with a gunfighter seat on it, (pillion sits high if at all)
88Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Sat Apr 05, 2014 4:52 am
snowbeard
snowbeard
looks great! I can see the opinions of removing the bags, but the mounts don't detract too much with them off, and my personal opinion is that a moto without some way to carry things is nearly useless. Who wants to take the car every time you need to bring something home or take it with you! Ride all the time!!  Too good to scrap - Page 2 112350
89Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Sat Apr 05, 2014 1:37 pm
The bike looks very sharp Bushy.
Well done.
The purists can't bellyache too much...at least there is another K on the road and that's a good thing.
More orange bikes...I'm hearing ya ainsjac!
90Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Mon Jun 16, 2014 9:06 pm
bushyintas
bushyintas
Further development on the project....
Installed an aftermarket gear display in the instrument cluster. It replaces the worn out LCD display with a 13mm Led 7 segment display, it fits with a bit of tweaking after you remove the original gear display and circuit board.
Too good to scrap - Page 2 Gear_i13
The whole wiring loom of this display threads out through a grommet hole drilled into the base if the instrument cluster and the attached via a plug to the rest of the circuit that I made up on a ''breadboard'' using 12 volt mini relays, Turning the three wire input from the gear selector mechanism on the rear of the gearbox to a six wire output for the LED display and one output for connection (positive +) to the starter circuit so I can start the engine without squeezing the clutch lever.
Too good to scrap - Page 2 Gear_c12
Relay Type as pictured
HY4100F-DC12V Mini Electronic Power Relay DC 12V 6 Pin 6Pin 1Ω 1A
Too good to scrap - Page 2 Relay_10
I will keep you posted all works ok so far, more photos when finally installed.
Bushy
91Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Tue Jun 17, 2014 1:49 am
jlmk100
jlmk100
Good use of parts well done Cool
92Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Fri Jul 25, 2014 10:45 am
bushyintas
bushyintas
I now have a fault to fix with my speedo, I have looked at all the threads dealing with this but none match my fault.
Speedo works fine for the first few K's but then climbs 20 to 30 Km/h higher on the dial until you slow down then the cycle starts again.
I have pulled the cluster apart, detox all electrics, twisted pins etc, etc but still no change. All calibrated well on Karamba, all I can now think of is a fault in the final
drive, dirt on slotted disc ?, possibly foaming gear oil  ?
Thoughts please anyone.
This fault was there before I fitted the gear indicator so I think its unrelated.
Bushy
93Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Fri Jul 25, 2014 11:01 am
There could be some foreign object in the magnetic drive for the needle within the instrument cluster. I have seen this in cable driven speedos that were suffering similar problems.
I doubt that anything would be wrong in the final drive as anything there would tend to mask pulses and slow the speedo down
94Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Fri Jul 25, 2014 7:24 pm
just noticed the instruments bushy ...they appear to be the early series 84-85  (with the 7 and 4 litre indicators )
on some of the early ones I have seen the meters do seem to ...erm... over indicate ..time to time
im sure there was some change in the electronic components in the design of both the speedo drive and tacho
just thinking aloud here ...
I would change the electrolytic capacitors on both boards first off
change them out for the same value as marked .....I would think that after 30 odd years they would have dried out and be far less compliant  doing the job that they need to do
just a thought
95Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Sun Feb 08, 2015 3:42 pm
bushyintas
bushyintas
Gear Display Circuit board arrived on Friday 6th Feb, installed today, works and looks great, well worth the wait.
thanks Rob Mac for all your efforts.
Too good to scrap - Page 2 Gear_d10
Bushy
96Back to top Go down   Too good to scrap - Page 2 Empty Re: Too good to scrap Mon Feb 09, 2015 6:53 pm
good work there bushy ...cheers
good to se the robmack solution getting around the world ...cheers rob
