1Back to top Go down   Bar end weights Empty Bar end weights Sat Aug 04, 2012 6:19 pm
hitmanh
Is there some special technique for getting the bar end weights off K100LT bars? Bolt came out easy enough, but can't get the actual end weights to shift at all. So, have i missed something or is if time for the big feck off mallet?
2Back to top Go down   Bar end weights Empty Re: Bar end weights Sat Aug 04, 2012 6:36 pm
Our friend corrosion could have been on a visit I`ll guess.
Have a look at the pictures a bit down in this thread,
could be a bit easier when you see how it look like on the inside.
3Back to top Go down   Bar end weights Empty Re: Bar end weights Sat Aug 04, 2012 9:47 pm
Slack the screw and give it a 'wack' with a hammer. This should release the tension and permit to remove the bar ends.
CF
Bar end weights Frog15Bar end weights Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
