1Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty bmw k 100 rt buzz from 2000 rpm Sun Mar 25, 2012 11:15 am
nino
For years I had a problem with buzzing from 2000 rpm. Tighten all screws front, rear, everywhere, but problem remained the same. Finally found that buzz comes from front brake tube situated in head od frame, in tube which connects triple clamps. I disconnected brake line, removed brake tube and isolated it with plastic isolation tape from bottom to top. Then put some thin layer of grease, put it back and connected the brake line. Removed the air from system I went for ride. Cant believe no buzzing at all any more, even between 3 - 4 th rpm.
If you want to try be carefull. Envelope the brake tube only once. Except isolation tape you can use plastic tube for isolation of electrice wire, diameter of 30 mm.
2Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Sun Mar 25, 2012 11:43 am
great tip nino .....thanks
i too have a buzz occur ....but it seems to be from the fairing on the right hand side ...i undid the pocket brackets ...and isolated it somewhat then did the brackets up again ,,,,,buzz gone ....woopee !!!
3Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Sun Mar 25, 2012 11:53 am
nino
charlie99 wrote:great tip nino .....thanks
I thought buzz come from right pocket in the fairing and tighten it. It was better but not solved. Finally understood its metal to metal contact of tubes in head of frame. Charlie try it
4Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Sun Mar 25, 2012 12:09 pm
ReneZ
ReneZ
Nino, was that pipe seated with the rubber ring? Normally there's a rubber ring at the bottom and the top is fixed with the nylon nut (so I thought).
Rene
BMW K100 - 1985 (0030029) Scotland bmw k 100 rt buzz from 2000 rpm Rain
5Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Sun Mar 25, 2012 12:16 pm
nino
ReneZ wrote:Nino, was that pipe seated with the rubber ring? Normally there's a rubber ring at the bottom and the top is fixed with the nylon nut (so I thought).
Yes, it has ruber ring at the bottom and plastic nut at the top. But, thats obviously isnt enough. Start the engine go to 1,5, 2, 2,5 rpm put your ear near the place and you will hear buzzing.
6Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Sun Mar 25, 2012 12:19 pm
thanks nino ...i shall indeed
7Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty bmw k 100 rt buzz from 2000 rpm Sun Mar 25, 2012 11:42 pm
Thanks for that info
I have a real buzz sets in at 5,000 rpm and sounds like it is coming from the instrument consol, sort of.
I thought there might be bits of the broken speedo cogs floating around but it may well be behind all that.
It's like a speed warning. goes off at 110 klm in 5th.
8Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Mon Mar 26, 2012 2:24 am
nino
RT wrote:Thanks for that info
I meant could be a speedo or rev counterand was horrified. Fortunately it wasnt. Just isolate metal to metal contact in frame head. Regards
9Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty How to eliminate bar weights buzz? Thu Jun 07, 2012 11:10 am
nino
I believe to solve bar ends buzzing by puting one more O ring on it. I removed bar weight and cut round slot like existing slot ( in middle of each weight). New slot is cca 3 mm from the end (or begining) of inner part of each weight. Then is necesary to put O rings on each new slot and screw weights back in bars.
Short drive - no more buzz around 2 k rpm.
10Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Thu Jun 07, 2012 11:53 am
Any picture of where you put the "cut" Nino?
bmw k 100 rt buzz from 2000 rpm Ir-log1188....May contain nuts!bmw k 100 rt buzz from 2000 rpm Ir-log11
K75RTP - 1994
11Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Thu Jun 07, 2012 12:22 pm
nino
88KE wrote:Any picture of where you put the "cut" Nino?
Sorry, I lost a camera few days ago. I ll ask my neighbor for help.
12Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Thu Jun 07, 2012 2:37 pm
Living in a less populated area, Nino?........we`re waiting.bmw k 100 rt buzz from 2000 rpm Laughi10
13Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Thu Jun 07, 2012 2:38 pm
nino
Inge K. wrote:Living in a less populated area, Nino?........we`re waiting.bmw k 100 rt buzz from 2000 rpm Laughi10
In ten minutes
14Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Thu Jun 07, 2012 3:20 pm
nino
nino wrote:Picturebmw k 100 rt buzz from 2000 rpm Bar_en16
bmw k 100 rt buzz from 2000 rpm Bar_en17bmw k 100 rt buzz from 2000 rpm Bar_en18
Its not machined., I made from hand using grinder. But weighst sit tight in bars - no more buzz
15Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Thu Jun 07, 2012 3:32 pm
A bit after scheme bmw k 100 rt buzz from 2000 rpm 652573 ...........well done, Nino bmw k 100 rt buzz from 2000 rpm 112350 ...nice photos, thanks for this info.
16Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Thu Jun 07, 2012 3:53 pm
Good idea Nino. Thanks for the pics - I'll do this too.
88KE
Last edited by 88KE on Thu Jun 07, 2012 8:18 pm; edited 1 time in total (Reason for editing : Typo)
K75RTP - 1994
17Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Thu Jun 07, 2012 3:59 pm
nino
After few short drives around I think it works.
18Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Crying Thu Jun 07, 2012 7:42 pm
ffbikersa
ffbikersa
In ten minutes
Yeah and when I asked for a pic how you installed the hockey puck on your sidestand, was no neighbour in the vicinity Crying or Very sad
19Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Merged buzzing 'bars and the cure. Thu Jun 07, 2012 9:58 pm
Same topic and issue, and it made sense to, so I merged them.
20Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Fri Jun 08, 2012 1:33 am
nino
Yes, in both case the source of noise is the same, tube in tube, metal to metal direct contact.Isolating front brake tube in frame head solved buzz partially, then few days ago while driving on highway noticed when cover bar weights with hands buzz disapear. So decided to isolate weights with additional O rings.
Later today I ll go for about 600 km drive, from Zagreb home to Dubrovnik. When come I ll send few words about buzz experience after intervention.
21Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Fri Jun 08, 2012 3:10 am
Aye, some times we enjoy a good buzz, other times it's not fun. :smoke:
22Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Sat Jun 09, 2012 2:04 pm
nino
nino wrote:Yes, in both case the source of noise is the same, tube in tube, metal to metal direct contact.Isolating front brake tube in frame head solved buzz partially, then few days ago while driving on highway noticed when cover bar weights with hands buzz disapear. So decided to isolate weights with additional O rings.
Just finished the trip from Zagreb to Dubrovnik (460 km country roads, 100 km highway). Nice weather, 30 degr. a lot of bikes on the road (mostly bmw gs 1200). Tested modified bar weights with additional O ring on my bike. Much, much better, no buzzing just a clean engine sound. Reccomend.
23Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Thanks Nino! Thu Oct 04, 2012 1:18 pm
KbikeJohnny
KbikeJohnny
Hello Nino,
Thank you for posting your fix for the buzzing sound. I have ridden K100RT bikes since '86, and the whole time that sound has bothered me. I tried to figure out where it was coming from, but did not have success. Then 3 weeks ago I saw your post. I used heat-shrink tubing for the sleeve, shrunk it on and it worked fine. The sound is completely gone. Everyone who thinks they are hearing the buzzing sound should try this. Thanks again.
Keep the shiny side up!
John
24Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Thu Oct 04, 2012 2:52 pm
nino
Hello Johny, where did you use heat shrink tubing, in frame head, or on bar weights, or on both?
Regards
25Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Thu Oct 04, 2012 4:27 pm
greggaz
greggaz
I too have been looking for this similar noise thanks for the ideas
Baja Red 1985 K100RT
26Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Sat Oct 06, 2012 12:06 am
yankeeone
Nino,
I have had a buzz for a while, I have taped , tightened, screwed, bolted, shimed, ect, still have the buzz that I thought was the spedo console, I switched out the spedos , still the buz, so this brake line , all I need to do is pull the line from the master, undo a nut on the top of the steering head and drop the splitter, put some tape on it , put it all back?
Brian
27Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Sat Oct 06, 2012 8:31 pm
yankeeone
by god it worked
28Back to top Go down   bmw k 100 rt buzz from 2000 rpm Empty Re: bmw k 100 rt buzz from 2000 rpm Sun Oct 07, 2012 4:04 am
ReneZ
ReneZ
Well done! Nino - great tip!!
Rene
