Weird Clutch issue, won't disengage. Wed Aug 01, 2012 12:57 pm
TSBT
![avatar](https://i.servimg.com/u/f41/11/71/56/74/avatar10.jpg)
![Silver member Silver member](https://i.servimg.com/u/f80/11/71/56/74/bmw-2s10.gif)
Adjusted the clutch after replacing the friction plate/o-ring and for some reason, the minute I pull the clutch-lever in and put the bike in gear on the center stand, the wheel spins. Readjusted it many times following the adjustment procedure exactly, but get the same result. Thoughts on what might be causing this? I surly hope I don't have to take the tranny off again. It's almost like the clutch rod isn't floating the clutch plate.
Chris
