1 Clutch disengage Sat Jun 14, 2014 11:27 am
jlmk100
Managed to get the bike to crank over ok via slave battery .
The clutch wont disengage although the arm moves when you use the lever .
Thoughts on sorting this ? I do plan on taking the engine out when I start properly so if nec will separate if nec was going to leave connected if all ok.
