1Back to top Go down   grease used on rear drive splines Empty grease used on rear drive splines Thu Feb 21, 2013 7:58 am
coopz
coopz
What grease should I use on rear drive splines in Australia Cheers Coopz
1985 K100 RS
I ordered and received a tube of purpose made grease from motobins in the UK.....
KKlompy grease used on rear drive splines 2854237993
grease used on rear drive splines Au-log10
You can use ROCOL GA 50 it's available from most auto stores and is used in assembly of engines, especially the cam shaft and followers. Its 50% moly and is the ducks nutz
4Back to top Go down   grease used on rear drive splines Empty Grease for rear splines Thu Feb 21, 2013 5:47 pm
coopz
coopz
Thanks for prompt replies Coopz
1985 K100 RS
