1Back to top Go down   k1100 fairing Empty k1100 fairing Thu 31 May 2012, 04:29
I've found a k1100 top and lower front fairing completed with lights, indicators mirrors and electric screen (the bit I'm really interested in) for sale at reasonable money from a guy who's gone nekkid!
I know the screen and top fairing will graft straight onto my k100LT but what about the lower cover. Will I need to source brackets and or inners if used it?
If I buy I've got to take it as a job lot so if anyone here has and interest PM me.
88KE
k1100 fairing Ir-log1188....May contain nuts!k1100 fairing Ir-log11
K75RTP - 1994
2Back to top Go down   k1100 fairing Empty Re: k1100 fairing Thu 31 May 2012, 05:01
The bracketry used to secure the K100LT fairing are different than those used on the K100LT; however, the points on the frame and engine to which they fasten are the same. The brackets are used to secure the upper fairing primarily. The lower fairing components mount to the upper fairing and not to the frame (similar to the K100RT/LT) except for one bracket pair that secures the lower fairing to the engine. I'd recommend getting the correct brackets along with the fairing components. After all, the guy will not need the brackets if he's converting his bike to nekkid. Have you thought about how the speedometer will be mounted when you change out your fairing?
3Back to top Go down   k1100 fairing Empty Re: k1100 fairing Thu 31 May 2012, 05:05
ReneZ
ReneZ
Hi, if the mirror pods are still good I'm interested. Please let me know by PM? Colour, condition, price? Thanks.
Rene
BMW K100 - 1985 (0030029) Scotland k1100 fairing Rain
4Back to top Go down   k1100 fairing Empty Re: k1100 fairing Thu 31 May 2012, 05:21
The fairing bracket of the LT is different than the RT.
On the LT, the instrument cluster is attached to the fairing bracket. On the RT, the cluster is installed on the triple tee. If you can get this bracket (# Cool, you wont have any problems.
k1100 fairing K1100_10
k1100 fairing Frog15k1100 fairing Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
5Back to top Go down   k1100 fairing Empty Re: k1100 fairing Thu 31 May 2012, 13:34
Thanks Robmack and CF, I guess the tree will be available if he's got a new headlamp mount etc. If I can get it then no worries, If not I believe I have to make a spacer of about 25mm for the instrument cluster and trim my front bracket (which is bent) for the motor - so getting the 1100 one solves 2 things.
Rene Z - pm sent.
88KE
K75RTP - 1994
