1Back to top Go down   Most lights are gone Empty Most lights are gone Mon Apr 23, 2012 2:56 am
dennisg844
All of a sudden, the headlight, directional lights, running light, and instrument cluster backlights stopped working. The brake light works. The indicator lights (battery, temp, choke, etc.) work.
Any ideas? Thanks,
Dennis
p.s. (I haven't yet installed the new temp sensor I've been talking about in another post.)
2Back to top Go down   Most lights are gone Empty Re: Most lights are gone Mon Apr 23, 2012 3:11 am
on the "portal page" is a link to the wiring diagram lots of things to be found there
good luck
3Back to top Go down   Most lights are gone Empty Re: Most lights are gone Mon Apr 23, 2012 5:51 am
Check your load shedding relay, relay coil is grounded through the starter brushes.
It heaps of info about it in here, if you search a bit.
4Back to top Go down   Most lights are gone Empty Problem solved!! Wed Apr 25, 2012 1:57 pm
dennisg844
I grounded the starter as per Charlie's suggestion and that did not change anything, so the starter brushes were not the problem. Then I swapped the horn relay with the headlight/load shed relay and everything works perfectly! I used the diagram in Paul Glaves article: http://www.ibmwr.org/ktech/relay-box.shtml
Thanks all,
Dennis
5Back to top Go down   Most lights are gone Empty Re: Most lights are gone Wed Apr 25, 2012 2:02 pm
good result ...start at the simple things huh ?
