1 Indicators, lights, horn, brake lights all ok but no dash lights or ignition. Tue Jun 10, 2014 10:35 am
selly780
Hi all I am in the process of getting my K75RT back on the road. It has been starting first push of the switch and all seemed good. Took it for a spin down to the garage to get an MOT cert and it ran well, so was in the process of cleaning it up but now it fails to start. All indicators, lights, horn etc work but strangely the neutral light, fuel level indicator, gear position indicator are not working & the engine does not turn over on the button. I have visually checked the fuses and all seem ok. I took the RH switch assembly off and sprayed it with WD40 to disperse any water that may have got in as I did cautiously jet wash the worst of the dirt off the bike as it had been standing under a cover for a few months. But as I said it has been started and run occasionally and ran down to the garage without any issues. I have been searching for similar posts and I am going to check the main earth from the battery to the gear box tonight as some have suggested, but if it was a bad earth wouldn't it also prevent the lights working ? Any suggestions would be appreciated. Thanks
Warren ( England)
Warren ( England)
