Number of posts : 11701
some of us have replaced the pump ....secondhand like ....out of other vehicles in this case cars ...i think i recall someone finding a perfect match out of a puegeot or something similar about 1600 cc
but first undo the riders right hand side cover and you will find a 4 pole connection that connects the fuel pump fuel sender etc ....quite often the poles become corroded and high resistance .....crimping the socket part is often a fix after cleaning the contacts areas .
but before you do mutch of anything please go to the portal page and read the info there ...in the section "so you just bought a k100 now what ?"
old fuel ....and contaminants usually suck up into the pump and fuel filter ....blocking it .
sad to hear that it happened so soon after your purchase ....
there are lots of threads to fuel pump replacement all through the forum ....just use the search feature
hope this helps
