51 Re: [Solved] Non starting 92 K100LT Sun May 13, 2012 11:33 pm
I really appreciate the help on this.
I went at it yesterday and today.
Took out ICU, cleaned everything up, it did look fine and no evidence of any water ingress inside it, like new. Refitted and connected back up. No difference.
Swapped some relays around in the electrical box under the tank. There are three identical ones numbered 311. The book says 2 but I think the third is the headlight relay. No difference.
Disconnected and reconnected and clealed the multi connectors from the handlebar switches. No difference.
Swapped fuse 7 with a spare fuse and no difference.
When I put all back together it ran for about 10 minutes no problem. Used kill switch quite a few times and it restarted normally, no problem. At about 20 minutes it cut out and problem showed up again. I tried keeping revs up to see if this would prevent cutting out, it did not help. Actually seemed like fuel cut off. But when I press starter button again the fuel pump is working fine even though the starter fails to do anything.
This time I kept my finger on the starter button and after about 15 seconds the starter engaged and turned over briefly. This happened a number of times...delay and then engaged.
So, my guess is the starter button [checked connections], load shed relay [not checked], starter relay [already replaced with a new one] or starter [twice taken out and stripped -but I am open to being told I have not done it right]. As for the temperature sensor I know the coolant level is correct. Its due a change on next service in about 2 weeks so am leaving alone.
If I turn on the lights and then press the starter button the lights do not dim so there is no power drain happening making me wonder is it handlebar switching. Would running a wire from battery to the starter motor when this happens, as a test, be risky?
If a guess is the ICU I can get one from motorworks, same with load shed relay.
Questions now is: could there be a fuel supply/fuel pressure/injector problem that could cause this? If there is insufficient fuel pressure or fuel supply [eg fuel filter/pump fault- tank has done 23 miles from a full tank so plenty in tank] does this translate into preventing the starter from engaging? Reading posts re injectors I am wondering could this be a problem?
Was anice sunny day for a run and a little frustrating.
