1Back to top Go down   (Solved) K1 (16V) not starting Empty (Solved) K1 (16V) not starting Fri Nov 18, 2016 8:25 am
K1 not starting.
Symptom after a very successful run I arrived at destination and parked bike. I needed to move it 5 mins later and it would not start.
As away from home initial troubleshooting was limited but did eliminate side stand switch and fuses.
At this stage fuel pump was not working.
Bike was then trailered home.
As I am fortunate to have a few spares I replaced the complete tank (from my K1100RS).
No change. I then tried a spare Motronic and success she started. Went back to old Motronic and again she started. Re-fitted original tank and again she started. Put everything back together and left bike for a few weeks.
Next time I went to start her I had no luck but fuel pump was activating.
What I have done so far.
1.       She turns over perfectly so not the battery.
2.       Fuel pump now activates when ignition switched on.
3.       Motronic has been replaced with known good one.
4.       I have checked the air and temp sensors and they meter out correctly from Motronic connector.
5.       TPS also checked and set and it also meters out correctly
6.       Have again replaced fuel tank with known good pump and filter and new fuel.
7.       Cleaned and checked spark plugs and they all spark (outside the engine)
8.       Removed injector rail and injectors are all working *
9.       Tested Hall effect sensors (thanks CF for the guide) and they are both good.
10.   Fuel pipes are on correctly
11.   Side stand switch works correctly i.e. when sidestand down fuel pump does not activate.
12.   All fuel injection rubbers were replaced last year and injectors serviced.
13.    Bike completed a 3500 km run to Germany in May without any issue.
14.   Starter motor cleaned and new brushes fitted.
15.   Earth cables cleaned at Starter motor, under coils and under tank (frame).
I am now thinking the fuel pressure regulator may be the problem and have ordered a pressure meter to test.
* The injectors are pulsing fuel but unsure if enough is being delivered.
Any ideas welcome so I can get this K1 back running.
(Solved) K1 (16V) not starting Ir-log10
 ;BMW; K1200RS Red
2Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Fri Nov 18, 2016 8:33 am
BobT
BobT
My 16v was playing up in exactly the same way with all the things tried that you have done. In the end I took the starter motor out and cleaned up the brushes, put everything back together and now it starts with no problem.
It might have been that I cleaned the starter, it also might have been that I took so many electrical and earth connections off and then refitted them, not sure, but it works now.
3Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Fri Nov 18, 2016 10:12 am
Thanks Bob
I will give that a try and report back.
 ;BMW; K1200RS Red
4Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Fri Nov 18, 2016 10:15 am
I would say bad connection/earth, possibly the plug for the motronic and the plug to the temp sensor just behind the radiator.
5Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Sun Nov 20, 2016 2:09 pm
Starter motor cleaned and new brushes fitted and some earthling points cleaned.
She now attempts to fire, at first attempt of starting, so definite progress.
Next step is to remove airbox and check temperature sensor.
 ;BMW; K1200RS Red
6Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Sat Feb 25, 2017 11:25 am
She lives again . I replaced water temperature sensor and also new plugs and fuel filter and she eventually started.
 ;BMW; K1200RS Red
7Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Sat Feb 25, 2017 2:23 pm
Ringfad wrote:Next step is to remove airbox and check temperature sensor.
In post #1 you wrote in #4 of your list of things you had done so far that the temp sensor was metering correctly. In post #5 you wrote that you intended to check the temp sensor. Was the temp sensor you wrote about checking in post #5 and about replacing in post #6 the same one that was working in post #4?  bounce
8Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Sat Feb 25, 2017 2:54 pm
Correct.
I am still not sure that I have solved this even though she is now starting.
Next test will be on the road, but will not be travelling too far initially.
 ;BMW; K1200RS Red
9Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Sun Mar 12, 2017 6:00 pm
I have been starting the K1 every few days without a problem and decided today to go out for a run.
I have a test route I use that brings me through a village then dual carriageway and then onto a motorway.
Perfect on the way out and most of the way back, the K1 was running perfectly and even touched 130km on the motorway.
As I slowed for the lights returning to the village she stalled, I tried to bump her in gear as I slowed but all I got was a bang as fuel burnt.
Then nothing - back to the drawing board Crying or Very sad .
She turns over, fuel pump is working but it was getting dark so not much time to trouble shoot
Luckily I was about 2km from home and a very kind biker called Paul stopped and after replacing the Motronic (still nothing) he towed me home.
Interesting being towed on a K1 by a Honda Deauville Very Happy
Now I think I should re-test the hall effect sensors unless anyone as another ideas.
 ;BMW; K1200RS Red
10Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Sun Mar 12, 2017 6:24 pm
I am sorry that I cannot be of a lot of help for you as I am not familiar with the Motronic system.
However, jumpinjimmy had a similar problem with a K100 2v.
I spent at least over a month on private Email with him to try to solve it without going to the expense of replacing everything.
At the end, it was the ignition computer that had an intermittent fault.
How we found it?
I asked him to put a gauge on the fuel pressure line and an induction timing light on the ignition when the bike was not starting. It allowed us to pinpoint the problem to the ignition computer.
This technique may help you to pinpoint your problem (Fuel injection or ignition).
If somebody send me a nice K1 or K100 4V for a year, I will be able to write a troubleshooting guide for the Motronic Razz .
Good luck to quickly find your problem.
CF
(Solved) K1 (16V) not starting Frog15(Solved) K1 (16V) not starting Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
11Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Sun Mar 12, 2017 6:33 pm
Thanks CF
I will keep working away on it.
My K1100RS has pretty much the same ignition system so I might 'borrow' a few parts from it to try and get this resolved.
 ;BMW; K1200RS Red
12Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Mon Mar 27, 2017 4:39 pm
I might have it solved.
I swapped  the ignition module (Bosch 0227100200) from by K1100RS and now have a spark.
This module fits to the front of the battery box on 16v's.
I refitted the old module and again a spark.
I have cleaned all the connections on the old one and just back from a 50km run.
So either this connector was loose are I had a bad connection.
 ;BMW; K1200RS Red
13Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Mon Mar 27, 2017 6:33 pm
Well, the kettle's on if you want to come and test it...
14Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Mon Mar 27, 2017 8:15 pm
The bloody connector.... The hint is when you remove it for battery recharge or replacement . If the bike doesn't want to start this is the first place to check.
15Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Tue Mar 28, 2017 5:43 pm
Dai wrote:Well, the kettle's on if you want to come and test it...
Hi Dai
How would Sunday suit to test the kettle (and the K1) ?
 ;BMW; K1200RS Red
16Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Wed Mar 29, 2017 6:07 am
My grandfather came from very close to where Dai and Comberjohn live.
I loved the place but the thing that always made me smile was that his family never had a kettle. But 'cattle' was what you boiled your water in for your tea.
Its a most beautiful part of the country and no wonder the Mournes are so famous. So Dai may be needing a bigger one. Next time I will deliver the Christmas puddings personally.
Wonder would we get Dai on the Wild Atlantic Way?
17Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Wed Mar 29, 2017 7:21 am
Hi Dai
Sunday's fine - I'm on call this weekend so I'm going nowhere. Approximate time?
Olaf - I did a big chunk of the Donegal section of the WAW last year and thoroughly enjoyed it.
18Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Wed Mar 29, 2017 7:41 am
There is a big chunk a bit further south too.....including this:
You might spot Comberjohn on right and Mike D on left in the photo...! Simon midship and yours truly on the camera.
Mrs Doyle will make the tea!
(Solved) K1 (16V) not starting P7200710
19Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Wed Mar 29, 2017 4:05 pm
Hi Dai
How about 2-3 pm - I will drop over to Coney Island first to see the parents and then to you on the way home ( K1 permitting) ?
 ;BMW; K1200RS Red
20Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Wed Mar 29, 2017 6:42 pm
You're on. If no response from the house, knock on the garage door. I'm working on a BSA C15 ATM.
21Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Mon Apr 03, 2017 5:30 pm
Problem now seems to be resolved. It appears that the connection to this unit was bad or loose.
(Solved) K1 (16V) not starting K1_ign10
I managed a 402 km run yesterday with no issue and a very nice chat and cup of tea with Dai (Thanks Dai)
 ;BMW; K1200RS Red
22Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Mon Apr 03, 2017 5:40 pm
You're welcome. I ate the other macaroon as soon as you left. I never did do any work on the C15 but I did solve the bouncy needle problem on LFB. Now to do something about that wristbreaker of a clutch...
23Back to top Go down   (Solved) K1 (16V) not starting Empty Re: (Solved) K1 (16V) not starting Mon Apr 03, 2017 6:16 pm
Clutch Dai well mine was like that and a nice new BMW cable sorted it. I know its all good and to spec because it got a new friction plate and everything in there lubed up. If it was previously good when my cable went like yours it was badly frayed where the sun doesn't shine. Only found the damage after taking the cable out.
Macaroons.....my mum use to make those....
