1Back to top Go down   Headlight relay Empty Headlight relay Sun Jul 08, 2012 10:26 am
twincarb
twincarb
Just been looking into putting a couple of relays in for the headlight... But am trying to establish whats the best route to go... short and simple or adding some complexity into it...
Is the diagram I have drawn potentially going to be too slow in switching?
Just to clarify when I say old loom I mean the original conection to the headlamp...
My short and simple diagram:...
Headlight relay Headli10
Yamaha Thundercat
Headlight relay 169042Headlight relay 169034
2Back to top Go down   Headlight relay Empty Re: Headlight relay Sun Jul 08, 2012 10:31 am
I have what you call the simple one and I works just fine.
The bosch relays I used have a switching time of 10 - 12 milliseconds so I really don't think you will be concious of any lag.
3Back to top Go down   Headlight relay Empty Re: Headlight relay Sun Jul 08, 2012 11:20 am
short and simple works just fine twincarb .....and if you need you can go back to the original purdy easy ...(not that you would want to ) we gotta look after those poor old switches and wires .
4Back to top Go down   Headlight relay Empty Re: Headlight relay Sun Jul 08, 2012 4:46 pm
This is how I did mine:
http://k100rt.aforumfree.com/t1184-converting-k100rs-to-k100rt#6841
It echos your simpler design. Relay switching time has never been a problem and it has been working great for years now.
5Back to top Go down   Headlight relay Empty Re: Headlight relay Sun Jul 08, 2012 5:14 pm
twincarb
twincarb
thanks for the replys, Rob having had a quick read of your posts, so i can see CF reason for the full circuit, however I cant see anything going wrong with the simple method...
Yamaha Thundercat
6Back to top Go down   Headlight relay Empty Re: Headlight relay Sun Jul 08, 2012 11:06 pm
Twincarb,
The more complex solution has the same relay parts count than the simpler one but the added diodes prevent damage should the circuit be plugged in improperly. That is a mute point if you plan on making the circuit part of the wiring harness. The simpler circuit functions equally well, is easier to wire up and test and probably has slightly better reliability having a lower component count. I think you'll be happy with either one.
