951 Re: My 84 K100 RS restoration Mon May 30, 2016 4:04 am
Halo
Been using a citrus type
Go to page : 1 ... 11 ... 19, 20, 21
Halo wrote:It all went bad, I have had corrosion come to play since and it's all under that KBS rock hard coating , should have oven baked parts first as there was still moister in the parts , I sprayed in dry warm area but parts where left in shed in winter between sand blasting and spraying and the moist air finish is causing corrosion under the clear coat. What to do ? , I have stripped back to the engine and found that citrus based paint stripper can lift it but its really slow. I just can't spray silver as it is growing 3D under the surface once the clear coat is lifted off the corrosion just wipes off fine.
You know I forgot all about this in the last 3 years guys like you Rick G that just help others out Charlie, Blakey and you and the rest it never stops amazing me very generous people.RicK G wrote:Hmmm that makes it difficult. The citrus stripper may be best but it is a long process. Maybe some solvent to soften it to get a head start. Throttle bodies would be almost beyond worthwhile saving. I have a couple of sets you can have for the postage along with gearbox case and crank cover if you want them.
Halo wrote:Hey KyleMB thanks mate it's because of your response to this old thread that just mybe it's started again, don't know how easy it's going to be due to the major f up but I will try again
Halo
Halo wrote:Hi Charlie started this today again before finding out about Rossco, he was always a great advocate for this restore for me, he used to say I'm convincing the others your not some crazy obsessive restorer and a normal bloke come up for a ride to meet them so they know I'm right about you he would say to me, so I did.
I would love to resurrect this for him/me, I used to call Rossko several times a month when I was working on this , Rossko was always on my back to finish this instead of stuffing around with the K100/K1100 I did instead of this. I would like to make amends for him, my way to deal with his loss.
I was ready to put the fluids in and start the bike, Rossko suggested we should have a meet with other for the starting of the engine. I moved on to the other bike and never did start the engine with him, in retrospect it leaves a nasty lump in my throat.
Got any ideas on how to lift the KBS old mate.
:- sand blasting ?
:- talk to supplier of KBS ?
:- you can see where the stripper lifted the KBS in one photo but it took forever
Yep I totaly agree Olaf92KK 84WW Olaf wrote:Halo wrote:Hi Charlie started this today again before finding out about Rossco, he was always a great advocate for this restore for me, he used to say I'm convincing the others your not some crazy obsessive restorer and a normal bloke come up for a ride to meet them so they know I'm right about you he would say to me, so I did.
:- sand blasting ?
Those are good thoughts, to finish the K and I am thinking maybe to have the meet up with the some of the Krew. Rosskko was a great ambassador for the forum and I have no doubt wherever he is riding Ks now he would be looking out to see your on back on the road.
Life will always leave us with things that give us the lump in the throat, truth is Rosskko was a family first guy despite his love for Ks and the forum and he would probably have done the same thing. What better way to keep his spirit with us.
Thanks RT good advice , Luckily I'm having good success now with a non Methyl Chloride stripper it stays wet forever and just washes off with water, just smells like lemons etc.RT wrote:You can cover the goo with gladwrap, helps it stay sticky. Wear gloves and ventilate the area, that Methyl Chloride stripper is literally a killer.
Last edited by RicK G on Sun Sep 18, 2016 2:18 am; edited 1 time in total (Reason for editing : As above)
RicK G wrote:Interesting, I had some that had been cleaned and stored and one of them wouldn't work when I tried them, maybe they need something like CRC or just oil put in there to stop the pintle valve rusting shut. That carb cleaner leaves nothing on the faces so it would be easy for rusty the home wrecker to take hold.
hi rick just reading halos resto and wondering what the correct injectors for the 16 v motor are [ as i ended up buying it from him ] for my project bike hope all is well your end of the woods cheers woodcutterRicK G wrote:We'll get BlaKey back in his cage as soon as possible Jason
The K100 injector will have 280 50 705 on the plastic top part they are the correct ones for an 8v
thanks for the confirmation duck thats what i thought as i checked the numbers on the injectors and they were marked 280-150-705 and i had previously bought a set of those 4 pintle upgrade injectors from martin diaz from ebay [ dimarmotorsports ] out of canoga park CA and he said that the upgrade ones will be fine in the 4v motor as they had the same specs ie ohms and flow rates its all new to me as im a old carby man lol so i might give them a go in the 4v and see how they perform , if no go i'll get the original single pintle ones reco'd and shove them in , have picked up a 1992 k100 rs frame from sydney ,so progress will be made once that arrives here , i did not want to get a complete 16 valve bike and dismantle it to build a custom from it and take another good complete bike off the road , so im building this one up from parts bin items i have parts ive sourced from australia , germany , austria , USA - wisconsin fort lauderdale FL , UK , to coin a phrase , " a multiKultural bike lmao , the motor was the one halo bought for his '86 RS SE that got sold off for the FIZZER 1000 he rides now thanks again for the confirmation on the injectors keep in touch cheers and best regards woodcutterduck wrote:RicK G wrote:We'll get BlaKey back in his cage as soon as possible Jason
210s are for the 2V Ks.
705s are for 4V.
Similar topics
