Go to page : Previous  1 ... 7 ... 10, 11, 12 ... 16 ... 21  Next
View previous topic View next topic Go down  Message [Page 11 of 21]
501Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Mon Oct 15, 2012 6:23 pm
Halo wrote:My 84 K100 RS restoration - Page 11 Untitl10
Only people not doing anything are the ones not making mistakes.
Don't you think that I didn't make any mistakes when I rebuilt my K100?
The good thing is that we recognize it and share our bad luck with others.
Yes we feel sorry for you, but when you do this kind of restoration small mistakes are expected.
Just loosen the oil pan, pull the output seal and re-install the ring.
CF
502Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Mon Oct 15, 2012 6:50 pm
Halo
Halo
Cheers CF the belly aching stops now Very Happy, boy you are everywhere on this forum arn't you "omni present". Time to man up boy I love this forum
mentoring thrown in for free as well
Halo
84 K100RS 0014803
93 FZR1000 EXUP
503Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Mon Oct 15, 2012 7:07 pm
Halo wrote:mentoring thrown in for free as well
Halo
How many people follow your thread, and how many of them gained experience by reading your posts?
You see you are a very good player when it comes to mentoring.
Most of us start as ignorant and progress because of people like you sharing their experience.
My 84 K100 RS restoration - Page 11 112350
My 84 K100 RS restoration - Page 11 Frog15My 84 K100 RS restoration - Page 11 Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
504Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Mon Oct 15, 2012 7:09 pm
Halo
Halo
Cheers CF
84 K100RS 0014803
93 FZR1000 EXUP
505Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Mon Oct 15, 2012 7:16 pm
Mistakes is done all the time...eg post 496, 497....have a look around in other forums.....I`ll guess it`s only a few that tells the story about their mistakes.
Since the seeger ring was dirty I would guess it`s from your spare engine parts,
but I`m quite shure that no one on this forum being in the same situation........
would have a good sleep untill they have checked.....to be shure.
506Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Mon Oct 15, 2012 7:28 pm
Inge K. wrote:I`m quite shure that no one on this forum being in the same situation........
This is true. I would loose sleep over an issue like this.
This only proves our dedication to restore a bike in perfect condition.
Nothing is ever easy and the challenge is what makes us proud of our accomplishments.
Road blocks are only a bump as we have the support of our mates (No, I am not an Aussie to use this word Very Happy ). Here they are buddies. (in Canada, the word `mate`is well used on ships when everybody relies on each others for survival)
CF
507Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Mon Oct 15, 2012 7:40 pm
Halo
Halo
Yes the strip down will commence and I have learn't that my quality control is flawled so I will revise. Expanded drawings with torque settings labeled to the relevant parts would help etc. Thanks Inge K for your help as well with this do I need to replace the circlip ? do I need to replace the nut on the clutch plate ?.
Halo
84 K100RS 0014803
93 FZR1000 EXUP
508Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Mon Oct 15, 2012 7:44 pm
[quote= do I need to replace the nut on the clutch plate ?.
Halo[/quote]
According to BMW the nut should be replaced. Will I replace the nut if it was me?
Honestly NO.
This is your call.
CF
509Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Mon Oct 15, 2012 7:46 pm
Halo
Halo
Thanks CF agreed it was new/ replaced a month ago from motobins Smile CF in Australia eveyone is your mate until proven otherwise yes we do use the word loosely.
Halo
84 K100RS 0014803
93 FZR1000 EXUP
510Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Mon Oct 15, 2012 8:14 pm
As a thumb rule a lock nut is a one time use................
But in real life some have used them more than once w/o any problem.........
and yours is rather "fresh".
When you have unscrewed the nut, turn it back in, and feel if you got a good resistance at the outer end of the threads...you don`t need to get the whole shaft through the nut....if in doubt you could add some Loctite.
About the seeger ring, it don`t seem to have lost it`s tension since you measured the same inside dia. as the unused I got.
Then you have the diaphgram spring (which also is a one time use), it should be good tension on this against the seeger ring....so it could be a bit tricky to get the seeger ring into the grove.
511Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Mon Oct 15, 2012 8:30 pm
Halo
Halo
Cheers Inge K I will be stripping it right down again so reassembly should be ok it was finding all the torque settings that was time consuming.
Halo
84 K100RS 0014803
93 FZR1000 EXUP
512Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Mon Oct 15, 2012 9:02 pm
Chin up mate.
In a few kilometres time it will all be behind you.
513Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Mon Oct 15, 2012 9:23 pm
Halo
Halo
Thanks Saxon it was the first part of my rebuild done on a crummy old table before the metal benches were built (still no excuse) so it will give me a chance to check all parts again on the upside it will be a nice change to dismantle a clean engine on a proper work bench:D
Halo
84 K100RS 0014803
93 FZR1000 EXUP
514Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Mon Oct 15, 2012 9:28 pm
This will cheer you up and give a laugh but it was far from funny when it was happening.
I bought the K1100 and it need some work doing as they do and decided to sell the K100 but wanted to keep the gearbox because it was part of the paralever set up that I wqas going to put in the K100.
I rebuilt a K100 gearbox and installed it in the K100 and sold it. Then removed the box from the K1100 and bought seals and bearings and clutch etc to do at the same time. Rebuilt the gearbox, replaced the clutch and reinstalled then found on the bench the new rear main seal for the K11 so out with the box and in with the seal and back goes the box and next morning I see a drip of oil under the bike so I investigate. Sure enough its gear oil so out comes the box and the clutch is covered in oil. I had not drained the box when I removed it and while sitting on the floor the oil had managed to get into the input shaft where the pushrod goes so when I cleaned it all and put the box back the oil had pushed through onto the clutch. Cool put it all back and all is OK
Next The lass that bought the K100 said the bike was making a strange noise so I said bring it back and I found it was clutch related so out with the k100 box and found I had not gerased the wire ring and it was making the noise . greased it and she went on her way.
next I rego the K1100 and go for a ride with bert and charlie ,alby etc and the clutch is slipping so next day out with the box and clutch. Problem was the pressure plate and drive plate had dished so that about 3/16inch was contacting round the outer edge so I used a good pressure plate and machined a drive plate to flat and all was well after I reinstalled and so far thats it.
All in all over about 4 weeks 6 gearbox removals and I was getting quick at doing them.
Now I can laugh at it but I certainly wasn't seeing the funny side at the time.
515Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Mon Oct 15, 2012 9:56 pm
Halo
Halo
Yes thanks Rick G that did help you poor bugger I bet you didn't see the funny side of it at the time. Wish it wasn't so deep in the engine guts though.
Halo
84 K100RS 0014803
93 FZR1000 EXUP
516Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Mon Oct 15, 2012 11:56 pm
A few weeks ago while I was in Sydney I took out the old cooling fan and radiator and put new ones in. It ended up being quite an involved job because of the sidecar mounts, Took a few hours in the end with the help of two mates. We had to take the sidecar off more or less so we could rotate the radiator forward to get it out etc...After all this....I took the bike for a ride around Palm Beach and then back to Paul's and let it sit and idle....and idle...and idle...but no fan cut in. Eventually the red overheating light came on...I wasn't a happy camper.
I rode it the 450 or km home, all the while vaguely worried about it, but not overly so as there's not much traffic up through Gloucester etc. Got it home and parked it in the shed in disgust with the people I bought the fan from. I am doing the ride from Guyra to Melbourne and all points in between over xmas and started to wrack my brains about what to do about it...another fan? Where from? Alby had suggested I get an aftermarket one with higher revolutions etc and I should have followed his advice in the first place. Something would have to be done...as summer on the flatlands is apt to get a bit warm.
Then came Charlie and Alby to visit. They insisted on having a look at the bike and giving it a going over with the carb tune kit etc. They did a great job and also adjusted the idle which was a little high at idle.
" Hey mate....your fan was never going to work, you know......"
" Oh ( says I) why not?"
" You need to plug it in first................................"
517Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Tue Oct 16, 2012 2:46 am
tintock
tintock
Saxon7 wrote:...You need to plug it in first...
Brilliant! Thanks for that belly laugh at 0645h! Nearly lost my coffee! Smile
Who Cares Who Wins
518Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Tue Oct 16, 2012 3:37 am
STEVE1959
Halo, when you have your first ride on your bike all the setbacks will soon be forgotten, I have done a few full restorations in my time and the path to success is never easy. You will always have the odd thing like this happen. Walk away for a day or two and then get stuck back into it. It is going to be a stunning looking bike when you are finished.
519Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Tue Oct 16, 2012 4:52 am
Halo
Halo
Fantastic Saxon7 what a story, cheers
Steve you are right of coarse just abit of a shock at the time but l'm getting over it
Halo
84 K100RS 0014803
93 FZR1000 EXUP
520Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Two hours work Tue Oct 16, 2012 6:49 am
Halo
Halo
Well the stripdown is going well you learn from doing the job once so the time spent was productive I did this after work
My 84 K100 RS restoration - Page 11 Img_2226
My 84 K100 RS restoration - Page 11 Img_2227
Halo
84 K100RS 0014803
93 FZR1000 EXUP
521Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Tue Oct 16, 2012 7:00 am
tintock
tintock
You're not wasting any time at all. Good on you for getting stuck right in to the job, mate! My 84 K100 RS restoration - Page 11 112350
Who Cares Who Wins
522Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Tue Oct 16, 2012 7:06 am
Mate, you are better than me. That bike would have a tarp over it by now if it was at my house. Or ebay.
Did you get a new friction plate? The center looks very shiney. Cotton bud and tears again?
523Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Tue Oct 16, 2012 7:07 am
We`re all as excited as you about what hides behind the clutch.
524Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Tue Oct 16, 2012 7:40 am
woohoo looks brilliant halo
hope you remembered to seal up the lower tb runners with some drie bond .....(3 bond) works a treat ...hmm left mine at albys ...dang ....
525Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Tue Oct 16, 2012 9:24 am
Halo
Halo
Yes new clutch plate no tarp for this old girl thanks charlie see if I didnt strip her down again I wouldnt have used dry bond I still think they look just great when you have the whole drive train sitting there by itself.
Yes inge k cant wait to look i believe it wont be there as on my first page you can clearly see the part about a third down the page.
Halo
84 K100RS 0014803
93 FZR1000 EXUP
526Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Tue Oct 16, 2012 11:56 am
Halo wrote:Yes inge k cant wait to look i believe it wont be there as on my first page you can clearly see the part about a third down the page.
Yes, did see it at the bottom of the picture.
If it`s missing, your next step would be to search for the diaphgram spring.
527Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Tue Oct 16, 2012 1:30 pm
Amster
Amster
This restauration thread amazes me more and more.
Halo, by reading through this thread I started to believe you're supernatural, but you fould us all by showing some humanes.... Only to showcase some more extraordinary efforts and before we blinked our eyes Shocked , you already teir appart you amazing "brick" and start to fix you supposed mistake.(if any)
Halo, you're my hero
cheers cheers
Respect from up above My 84 K100 RS restoration - Page 11 212902
(since you are "down under")
K100 RT "86
"As a final touch, God created the Dutch"
My 84 K100 RS restoration - Page 11 631586 or My 84 K100 RS restoration - Page 11 631586_31
http://www.van-amstel.org
528Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Wed Oct 17, 2012 6:42 am
Halo
Halo
Thanks Amster just learning along the way and sharing the journey, well the shed is a mess with parts everywhere. I managed to pull apart what I had done within two long movies that I hired to keep the wife and kids happy (read busy) for the last two evenings, but anyway the verdicts out
My 84 K100 RS restoration - Page 11 Img_2310
I left the circlip out Shocked
My 84 K100 RS restoration - Page 11 Img_2311
My 84 K100 RS restoration - Page 11 Img_2228
Halo
84 K100RS 0014803
93 FZR1000 EXUP
529Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Wed Oct 17, 2012 6:48 am
Phew........!
530Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Wed Oct 17, 2012 6:49 am
I would need planning approval from 3 councils to get a shed like that built in my back yard. Very jealous.
Looks like your cunning system for parts catalogueing is working.
I did not get my bike as stripped as yours, but I guess leaving that clip out would have resulted in some nasty metal grinding and sparks?
After all this you must be busting a gut to start that motor.
531Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Wed Oct 17, 2012 6:55 am
Halo
Halo
Rossco you are EXACTLY correct I really want to kick her over as I have never started her yet
Halo
84 K100RS 0014803
93 FZR1000 EXUP
532Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Wed Oct 17, 2012 6:56 am
Don't forget the water and oil seals when closing the engine
I just saw on the picture that one O Ring is missing Very Happy
533Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Wed Oct 17, 2012 6:58 am
Toto_jp
that was lucky a cheap fix just more inconvenience imagine if you actually fired the old girl up
well done mate
K100 RS 1986
534Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Wed Oct 17, 2012 7:03 am
Halo
Halo
Yes lucky find but must learn from this one all parts inspection now to the catalog drawings
Thanks CF good catch there see your everywhere Very Happy (It was stuck to the other mating surface)
Halo
84 K100RS 0014803
93 FZR1000 EXUP
535Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Wed Oct 17, 2012 7:25 am
caferacer62
caferacer62
Geez Halo i just read this, man what a good thing that you found the snap ring before starting it up.
Bad luck but i see you have it all sorted. Nice work.
I see you have the same shed storage designer as i do. Smile
Keep up the great work and inspirational info and spirit. CF is right you know, the work you are doing and posting it up here inspires others to have a go too. All good i reckon.
Bert 2.0
My 84 K100 RS restoration - Page 11 170874
536Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Wed Oct 17, 2012 7:46 am
col
col
was well worth it to check
1991 k100lt "the enterprise"
537Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Wed Oct 17, 2012 10:30 pm
kfilipow
kfilipow
Gents, I do believe we should select a day and time to have a beer or two with Halo. One to comisserate (belatedly) and one to honor his hard work. Good job on the clip, two days to tear down and correct. Cheers to you Halo.
keith
538Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Wed Oct 17, 2012 11:27 pm
yankeeone
nice job going back in, I tell my son when we are working on his 69 MGB and run into tough problems "the key to success is perseverance", and you have it.
Good job!
539Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Thu Oct 18, 2012 8:39 am
Halo
Halo
Yes can't wait to finish the resto cafe racer so I can get my shed back!. Col the more I think about it I am very lucky to have checked and not started the engine as it was . Kfilipow shall I go and get an extra slub of beer for the beer fridge and be exspecting visitors?. Nice car Yankeeone yes you know whwt they say 10% brillance and 90% perseverence.
84 K100RS 0014803
93 FZR1000 EXUP
540Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Thu Oct 18, 2012 8:57 am
indeed halo
ably and i are still wondering about the lateral moovement of the output shaft ...how it affects the clutch ...vibrations and all sorts of things
a conundrum indeed !
love your work
541Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Thu Oct 18, 2012 9:01 am
Halo
Halo
Sounds to me Charlie like I should visit my local BMW shop and ask him if I should buy/fit in the SHIM, mine being the early model
CF?
Halo
84 K100RS 0014803
93 FZR1000 EXUP
542Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Thu Oct 18, 2012 10:30 am
charlie99 wrote:indeed halo
love your work
You shouldn't have any lateral movement in the output shaft. There will be quite a bit before you fit the clutch carrier but after that is fitted it should be solid as a rock. If it isn't then go looking for why.
543Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Thu Oct 18, 2012 12:58 pm
yankeeone
there is a shim between the output shaft and the clutch carrier.
544Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Thu Oct 18, 2012 6:52 pm
yankeeone wrote:there is a shim between the output shaft and the clutch carrier.
Yes there is a spacer.
Here are the references (part # 19)
My 84 K100 RS restoration - Page 11 Spacer10
CF
545Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Thu Oct 18, 2012 6:57 pm
perfect bert ...that explains it all ...
i must report that this moovement is reported to me , not witnessed
good to know there is solutions that should be applied ...thanks all
546Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Thu Oct 18, 2012 7:23 pm
The shims was used on later models, the change was late -85., earlier models have a diaphgram spring.
Also the bearing and the seeger ring was changed around the same time.
I think I`ve read somewhere that the improved parts can be used on older models, exept the bearing which is different mounted in the engine halves.
(locating clip on early models, shouldered bearing on late).
547Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Thu Oct 18, 2012 7:32 pm
Halo
Halo
Thanks Bert but I must be having a slow day as this shim is between the drive gear body and the bearing then the circlip the Haynes manual states the shim is not present on early K100's mine being an 84
My 84 K100 RS restoration - Page 11 Xsxs10
Then we have thrust washer for the clutch which is present on mine
My 84 K100 RS restoration - Page 11 Swswsw10
Halo
84 K100RS 0014803
93 FZR1000 EXUP
548Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Thu Oct 18, 2012 7:33 pm
thats what i thought too inge ,,,but couldnt see a way to install the newer bearing to the older crankcase ,,,im guessing alby saw the older style
sorry for the hijack halo ....was just thinking whilst you were there.. .these things could be checked
549Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Thu Oct 18, 2012 7:36 pm
Halo
Halo
No go for it Charlie I agree, I need to check for the presence of the diaphram spring that Inge K is talking about though I didn't strip down to the bearing after removing the circlip (dont know in restospect why I took of the circlip anyway). I'm guessing Inge K that the diaphram spring sits in the samre location as it shows the Shim that is before the bearing is inserted onto the shaft
Halo
84 K100RS 0014803
93 FZR1000 EXUP
550Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Thu Oct 18, 2012 7:53 pm
Halo, have a look at the anti backlash spring at Bert`s resto page.
Check if it`s any movement between the gears on yours.
Then if it might be a idea to dismantle these parts,
while you have the shaft out.............again.
Then you could add shims instead, which should be an improvement.
Just some thoughts...................
551Back to top Go down   My 84 K100 RS restoration - Page 11 Empty Re: My 84 K100 RS restoration Thu Oct 18, 2012 7:55 pm
Halo
Halo
Thanks Inge K I will do just that thanks for your help again.
Halo
84 K100RS 0014803
93 FZR1000 EXUP
View previous topic View next topic Back to top  Message [Page 11 of 21]
