901 Re: My 84 K100 RS restoration Tue Sep 24, 2013 8:35 pm
Halo
All good don't worry I'm not a prat just a yobo that likes to sleep in a swag and drink.
Halo
Halo
Halo wrote:All good don't worry I'm not a prat just a yobo that likes to sleep in a swag and drink.
Halo
I have a copy of the Two wheels K100 from 1984, took it to Tottenham , but forgot to share it around , can mail it to you.if you would like to include it to your pdfHalo wrote:Thanks for the goods words FLoyd_of_oz, yes work & selling & buying a house is the priority right now but all that will change december as I move to a house in the hills with alot less maintenance, that will cut me some slack so I can work on K bikes again. Anyway with the 84 packed away for the move I have turned my attention to stamp collecting or similar really magazines with K100 test within. My intention is to scan them and make available online for a read, any copy right issues with 30 year old magazines ?
Halo
Halo wrote:Ahh but your RT has a special place already for it in the workshop there. By the way I drank all of the Bundy last night you left thanks mate
Halo
just read this , tis a shame I missed it , your shirts are posted .Halo wrote:Cheers GroverK that would be great only just saw this response from you now for some reason. I have had another 3 delivered as well, wonder if Bert would give us an area in the forum for bike Mag articles, Charlie ???
Halo
Not sure why you think that should be a question Blakey.blaKey wrote:Wow! Great job.
Hey guys...paint weekend at Halo's place?
There was a previous discussion here that may be helpful. Don't forget to click the link in CF's post for lots more great info.tgolden wrote:I think your understanding of how the 4L/7L low fuel sensor works is generally correct. I've seen a technical description somewhere in my past, but I can't find it now.
That sensor is no longer available from BMW. I'd like to know what can be done to repair one if it needs it.
Regards
klamityboy wrote:There was a previous discussion here that may be helpful. Don't forget to click the link in CF's post for lots more great info.tgolden wrote:I think your understanding of how the 4L/7L low fuel sensor works is generally correct. I've seen a technical description somewhere in my past, but I can't find it now.
Regards
There is also this link about the float type of sensor.
Magic; just what the doctor ordered.duck wrote:85 and earlier Fuel Level Sender:
Brown - Ground
Green/White - Fuel Pump Power
Brown/White - 4L indicator in instrument cluster
Brown/Black - 7L indicator in instrument cluster
Somebody correct me if I'm wrong but it's my understanding that the 4 & 7 sensors are at different heights(lengths). When submerged in fuel, they are kept cool by the fuel around them. When the gas becomes low, they are exposed to air and heat up which completes a circuit and sends some sort of signal to the cluster via the Brown/White and Brown/Black wires. My GUESS is that it's a ground signal since the main color for both wires is brown.
Thanks will look up CF's post.tgolden wrote:klamityboy wrote:There was a previous discussion here that may be helpful. Don't forget to click the link in CF's post for lots more great info.tgolden wrote:I think your understanding of how the 4L/7L low fuel sensor works is generally correct. I've seen a technical description somewhere in my past, but I can't find it now.
Regards
Thank you for that information. I appears that the early type fuel level sensor could be repaired if needed.
Regards
Never tried to test one out of the tank but the suggestion of putting in and out of a cup of fuel sounds logical. I'd be probably use water instead of fuel though.Qinghai wrote:Magic; just what the doctor ordered.duck wrote:85 and earlier Fuel Level Sender:
Brown - Ground
My next question, ignore if I'm being a pain, have you devised a method of testing outside of the tank?
Qinghai Hugh
Good point.ReneZ wrote:Duck's description is right. The tube is easily opened and you can see the two elements for the two levels. There are some good pictures around.
I would not test it in water, as there are open solder jobs.
Similar topics
