Go to page : Previous  1 ... 5 ... 7, 8, 9 ... 14 ... 21  Next
View previous topic View next topic Go down  Message [Page 8 of 21]
351Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Mon Sep 03, 2012 6:36 pm
I bought the rub back wet/dry....600grit. I can assure you that your fingerprints will disappear from your hands, especially using the wet. I am hoping that my hands recover before next weekend...I cut my fingers getting the broken lights off my ute. I do know that thinners will find ALL cuts.
352Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Tue Sep 04, 2012 8:47 am
Erman
Erman
After trying and failing with acetone stripper and sanding on the parts for my Seca, I used a heat gun on low setting.
It worked pretty well for me. The old paint just flaked off. I could get the remaining small chips off with a steel wire brush.
Of course, later I had to prime it extra deep to fill in some of the scoring, but it turned out pretty well.
Bikes:
1984 BMW K1000RS
1984 Yamaha XJ750 Seca
353Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Next parts Thu Sep 06, 2012 12:58 am
Halo
Halo
I've been home with the cold all week but have come good abit and had a chance to complete the clean & prep the next lot of parts for the restore.
My 84 K100 RS restoration - Page 8 Img_1924
My 84 K100 RS restoration - Page 8 Img_1925
My 84 K100 RS restoration - Page 8 Img_1926
84 K100RS 0014803
93 FZR1000 EXUP
354Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Thu Sep 06, 2012 1:50 am
Halo
Halo
Just finished the final coat ended up using the spray gun
My 84 K100 RS restoration - Page 8 Img_1930
Halo
84 K100RS 0014803
93 FZR1000 EXUP
355Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Thu Sep 06, 2012 1:55 am
Did you actually clean inside the heads of those bolts???
Once again, very impressive work.
One thing I am not sure of is why you are clear coating everything?
Is it to make cleaning easier? Eliminate cleaning and just hose it off? Or is it to give you something to do next time you decide to restore the bike?
get well soon
356Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Thu Sep 06, 2012 2:16 am
Halo
Halo
Rossco my thinking is I want to keep my options open to turn it into something a little sicker later on (turbo, naked etc) as I did with my last bike, if naked I would like to see these parts clear al. The engine whole drive chain for my early 84 was all aluminium anyway
My 84 K100 RS restoration - Page 8 Jason_10
84 K100RS 0014803
93 FZR1000 EXUP
357Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Thu Sep 06, 2012 2:43 am
rossco wrote:Did you actually clean inside the heads of those bolts???
get well soon
Looking at that Kwaka, I'd say he's terminal!
358Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Thu Sep 06, 2012 4:13 pm
I always use cotton buds for cleaning the recesses in Allen screws, don't you, rossco? My 84 K100 RS restoration - Page 8 652573
359Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Thu Sep 06, 2012 6:00 pm
Yes Sean, terminal.
Paul,
Of course I use cotton buds. I don't know why you would suggest anyone would use anything else. It's obvious.
And I find they work better with the tears of kittens. Just gives that extra little bit of a polish.
360Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Thu Sep 06, 2012 6:14 pm
rossco wrote:Yes Sean, terminal.
Paul,
My 84 K100 RS restoration - Page 8 44271
361Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Thu Sep 06, 2012 8:27 pm
Oldgoat
Oldgoat
Looking good mate! Didn't know the KBS came in a rattle can? Cool What are you going to do with the fork internals?
OG
362Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Thu Sep 06, 2012 8:30 pm
Yeah but I like the bit about getting the tears from the kittens Evil or Very Mad
363Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Thu Sep 06, 2012 11:01 pm
Halo
Halo
Hi OG yes I thought the can would be good for the bolts I do all the time as setting up the spray gun is alot of work for a few bolts, but on the side says only good for 30 days after first use !. Forks are interesting as will do cosmetics now but need to think about what you did as well with your setup, if I remember you went the k75R inners with trick oil as well.
Due to the idea that Blakey had of the glass cabinet for the engine I was thinking the only issue with that is the resto halts so to be able to continue I will mount the following to the front of the bike so I can finish the resto but still leave it in the shed complete and not have to start it. All I need now is to work out the Vrooom Vroom noise setup, mybe some recordings gathered from the follow riders played back through the laptop & speakers mounted in the fairing.
That way I can still experience how it is to ride a K100 as I have never had the pleasure to do so yet.
My 84 K100 RS restoration - Page 8 Img_1931
Halo
84 K100RS 0014803
93 FZR1000 EXUP
364Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Fri Sep 07, 2012 6:13 am
Halo wrote:...... All I need now is to work out the Vrooom Vroom noise setup, mybe some recordings gathered from the follow riders played back through the laptop & speakers mounted in the fairing....
Halo
That'll work! Even better if you connect the volume control to the throttle grip so that you get more noise when you wind it open Very Happy
88KE
My 84 K100 RS restoration - Page 8 Ir-log1188....May contain nuts!My 84 K100 RS restoration - Page 8 Ir-log11
K75RTP - 1994
365Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Fri Sep 07, 2012 7:51 am
nice one halo ,
maybe bert and alby can get together for a recording session with their modified standard muflers...they sound pretty good btw
cheers mate !
366Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Fri Sep 07, 2012 9:24 am
Halo
Halo
Good point again Charlie I have pulled the headers off the pipes to polish now and was contemplating the pipe mod whats your personal view off it Charlie ?. More hp and better sound ?, thought it might need a clean inside I was wondering if some of the weight is caused by carbon buildup.
Halo
84 K100RS 0014803
93 FZR1000 EXUP
367Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Fri Sep 07, 2012 10:00 am
to be honest halo....i have been spoilt with the staintune ....but honestly the throaty roar of the moded pipes is more to my likeing .
berts mod is not too demanding in sound levels as to give you a headache from droning or some such ...(unlike many "open systems " that we see on some of those "hoons" cars or cutoff systems on bikes )
as we do more research into mixtures etc ...im sure we can attempt to increase our economy at lower to middle throttle settings , the throttle responce is well worth the modification
i think you might save at least a kilo of weight too , given that you will be cutting out mostly rusty components ...My 84 K100 RS restoration - Page 8 112350
368Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Fri Sep 07, 2012 10:20 am
Halo
Halo
Agreed Charlie hope your resting up as well mate
Halo
84 K100RS 0014803
93 FZR1000 EXUP
369Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Fri Sep 07, 2012 2:56 pm
Albyalbatross1
Albyalbatross1
Halo, I have noticed a definate increase in performance. Once up past 1800 rvs and climbiing through the gears. When i first got the muffler back i found the old girlvwas a lot more responsive and even seemed to pull away a bit better. There was a noticable increase in fuel consumption but as TWB pointed out it was just the " this sounds so good " new toy novelty riding.
There has been a small increase in fuel use that is really not worth worring about..mabey 2-3 k ltr two up. I still get 20k tltr. It sounds its best while accelerating and reallyvturns a few heads when other riders watch you start her up and it is not the usual whine....And it is kinda shiny....
370Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Fri Sep 07, 2012 7:16 pm
Halo
Halo
Sounds great Alby sign me up I will look at your thread in detail.
Halo
84 K100RS 0014803
93 FZR1000 EXUP
371Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Frame Sat Sep 08, 2012 1:57 am
Halo
Halo
Well another mile stone for me today the frame has been a big job to get finished, so many angles to sand blast from and detail. Sand blasted then polished with brass wire brush wheel alternating between large and small wheels on different grinders, only first coat done so far but thats it for today.
My 84 K100 RS restoration - Page 8 Img_1932
My 84 K100 RS restoration - Page 8 Img_1933
My 84 K100 RS restoration - Page 8 Img_1934
My 84 K100 RS restoration - Page 8 Img_1935
Halo
84 K100RS 0014803
93 FZR1000 EXUP
372Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sat Sep 08, 2012 4:20 am
Oh my. I paid to have my frame cleaned. Well done you.
And that is a milestone right there. Sticking the (first coat) painted from on the motor is awesome.
I bet you put it up there and then took a good few paces back, right hand rubbing your chin with a big cheesy grin on your mug and said out load 'I reckon that looks pretty damn good" "Did someone say beer o'clock?'
And you better clean that bedside table before you put it back in the house. She Will notice the new grey top.
rossco
373Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 12:28 am
My my halo, all these toy's you play with. makes being a grown up really worth while don't it. rossco very caring of you to remind halo about that bedside table, been there done then????? now what type of black is that, rattle can gloss or something different. The reason I ask is I was going to do mine but chickened out when i stripped the bodywork off of it and figured it to be painted in a satin gloss type, ended up grabbing the turtle polish and gave it a big clean and left it that way. Also sound wise, I would have to add that a set of 4 into 4's would have to compliment our bikes distinct sound, though I have as yet not seen it done.
374Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 1:01 am
was thinking 2 into 2 keith but that drive shaft kinda gets in the way ...but i guess a cross bridge under the g/box has been done before and mount off the foot peg braces...might look a little odd from the rear and problem in getting something that carries symetry to both sides .
btw an old "real" triumph tripple of the late 70s - 80s has mooved into the area ...the one with 3 exhausts on the right hand side (old school stuff ) but its noisy as hell. which kinda distracts from the grace that they once had . oh well we're all different huh ?
kinda waiting to see what bert can do for seanii halo ...should be impressive for the "outfit"
that frame looks good mate ....cheers !
375Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 1:03 am
K75cster wrote: Also sound wise, I would have to add that a set of 4 into 4's would have to compliment our bikes distinct sound, though I have as yet not seen it done.
Everyone knows that a 1 into 1 makes the best sound.
My 84 K100 RS restoration - Page 8 Hybrid10
376Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 1:08 am
eeeek !
omg inge thats awesome ......if you like that kinda thing .....something after a few brewskys ..perhaps ? My 84 K100 RS restoration - Page 8 44271
377Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 1:48 am
charlie99 wrote:was thinking 2 into 2 keith but that drive shaft kinda gets in the way ...but i guess a cross bridge under the g/box has been done before and mount off the foot peg braces...might look a little odd from the rear and problem in getting something that carries symetry to both sides .
2 into 2, Charlie.............K50?
Early in the development BMW also did have a double barrel exhauster,
at the same side.
When this issue comes up, it was a company that did make a 4 into 2 for the K100................but it`s to far back for my hard disk to remember the name,
or where I did see it.
378Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 2:06 am
I think the upper exhaust will require more muffling, what with that alternative fuel an all. a four into four would be the thing to hear, think back to the honda four and the big Kwacka 9's before they were replaced with the distinct howl of a four into one, they had a sound that we could capitalize on. They only need to cross under the bell housing and sweep back to look the part,
379Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 5:28 am
Halo
Halo
Yes the exhaust requires further investigation it's a really great section of the bike to modify inclusive of the airbox.
Thanks for the positive comments guys, K75cster about four pages back I did abit of a rightup with a photo on the KBS paint that I spray on.
The frame is completed now and boy was it an issue with cold weather playing havick but I made a small hot box for the frame with light drop sheet plastic and heat blower.
My 84 K100 RS restoration - Page 8 Img_1936
My 84 K100 RS restoration - Page 8 Img_1937
My 84 K100 RS restoration - Page 8 Img_1938
Halo
84 K100RS 0014803
93 FZR1000 EXUP
380Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 8:45 am
The clean up on the frame is very good work Halo! You're really forging ahead with the build. Good onya.
K75RTP - 1994
381Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 9:04 am
I do hope you have that rear drive proped up because if not the weight will cut through the front boot.
382Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 6:54 pm
Halo
Halo
Thanks 88KE yes the frame was another big tick on the resto, I was tempted to cut corners with the sand back to metal as who could tell but didn't as you can see from the raw steel photo. The black gloss KBS really s***s me though, the finish is better than the camera shows as it looks orange peelish on the camera and dimpled but up close has that flowing luster that I really like, looks to me like a high gloss issue. I know that for a great looking frame finish that even a can of flat black would look better but don't see that being as durable as the one pack KBS, the finish is very strong on this guff. I am wondering if I should put a fourth coat on the frame as the more I spray the more the paint evens out but its very thick already compared to a acrylic finish. It really does my head in with the KBS black but I love the KBS clear, all part of the learning curve it will all make sense in the long run no dought.
Rick G oops, was thinking that but still did it does it mean I will have to pull apart and inspect ? it's propped now insn't that all that matters Question
Halo
84 K100RS 0014803
93 FZR1000 EXUP
383Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 7:08 pm
With all of that new shine you'll have to paint the spring on this old Fox shock to match. I'll get it in the post tomorrow.
My 84 K100 RS restoration - Page 8 Imag0526
384Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 7:36 pm
Halo
Halo
Your a good man TWB your a BLOODY good man
Halo
84 K100RS 0014803
93 FZR1000 EXUP
385Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 8:37 pm
Its when left for a while it slowly mangles the boot or most important the drive drops quickly when the shock is removed and you aren't ready for the weight of it.
386Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 8:54 pm
Halo
Halo
Thanks Rick G, yes I let it down softly but its propted now and soon to be connected to TWB's shock, can't wait to clean it up just looking at the photo posted by TWB I want to start polishing & spraying it now.
Halo
84 K100RS 0014803
93 FZR1000 EXUP
387Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 10:30 pm
psst
i think i have another rebuild kit for the twin clicker halo ...the supplier sent me a few extras ....might come in handy in the furure .
it might pay to get a locking ring in addition the single unit in that pic too.
388Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 11:14 pm
Halo
Halo
charlie99 wrote:psst
? twin clicker I must be naff I don't get it Charlie
84 K100RS 0014803
93 FZR1000 EXUP
389Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 11:30 pm
Fox Twin Clicker is what the shock is known as. Also, though it's in no way essential to the functionality, there's one lock ring for the spring preload. My Bitubo is built that way too. Some might say two are needed to prevent the adjustment from changing as you ride, unlikely under spring tension.
390Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Sun Sep 09, 2012 11:44 pm
Halo
Halo
Thanks TWB for the clarification Charlie you have a rebuild kit Very Happy Very Happy Very Happy PM me please
Halo
84 K100RS 0014803
93 FZR1000 EXUP
391Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Mon Sep 10, 2012 1:11 am
halo they are great.... with adjustments for damping and rebound
youll love it !
392Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Mon Sep 10, 2012 8:37 pm
Halo
Halo
I decided that the frame top coat finish isnt that good as I have sprayed this too thick based on comments from others who spray that I know so I am going to strip it and start again to learn how to spray this black KBS Sad
Halo
84 K100RS 0014803
93 FZR1000 EXUP
393Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Mon Sep 10, 2012 10:37 pm
Oldgoat
Oldgoat
I admire you dedication to mastering the KBS Halo...keep after it!
OG
394Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Mon Sep 10, 2012 10:45 pm
Halo, I didn't get the post office today...the local Autumn county fair is in full swing and the roads are clogged with fairgoers and traffic's a bear to have to bear...but I'll get an hour off one arvo this week before they close to get there and get it posted. It sounds as though you're still in the refinish and rebuild stages anyway. It's looking good, but it is always best to do it right before you bolt it all back together. In the end you'll be more satisfied with your result.
395Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Tue Sep 11, 2012 12:06 am
Halo
Halo
Your right OG the black isn't my best friend yet but it looks like a good durable finish.
Not happy with my finish I set to sanding the frame back with wet & dry and found that after a couple of hours I prefer the finish, see what you think.
Learned a lesson thinner coats and sand backs (should have known).
Thanks TWB take your time no big rush, when you can fit it in mate.
My 84 K100 RS restoration - Page 8 Img_1939
My 84 K100 RS restoration - Page 8 Img_2011
My 84 K100 RS restoration - Page 8 Img_2010
Halo
84 K100RS 0014803
93 FZR1000 EXUP
396Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Tue Sep 11, 2012 7:35 am
Halo
Halo
Next parts to attack
My 84 K100 RS restoration - Page 8 Img_1941
Halo
84 K100RS 0014803
93 FZR1000 EXUP
397Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Tue Sep 11, 2012 7:53 am
col
col
looking great
just noticed your numbering on coils did you find another 2 cylinders in your cleanup
i think we your address so we all can send are parts to halos restoration shop
1991 k100lt "the enterprise"
398Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Tue Sep 11, 2012 8:17 am
Sorry Col, take a number and move to the back of the que Smile
399Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Tue Sep 11, 2012 6:56 pm
Halo
Halo
Thanks Col & Rossco I will keep that in mind when I run out of things to do on mine. Interesting you say this though as if I get any good at
this I would like another project towards the end of next year.
Halo
84 K100RS 0014803
93 FZR1000 EXUP
400Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Tue Sep 11, 2012 7:15 pm
dee why
dee why
Hi Halo,
Here is the link I have posted before which I used to get acquainted with my fox shock.
http://www.catfishracing.com/Suspension%20Manual/Fox%20Manual.pdf#search=%27fox%20shock%20setup%20manual%27
Cheers,
Dee Why
04/86 K100 VIN 0009479 Columbia Silver
401Back to top Go down   My 84 K100 RS restoration - Page 8 Empty Re: My 84 K100 RS restoration Tue Sep 11, 2012 7:44 pm
Halo
Halo
Thanks Dee why My 84 K100 RS restoration - Page 8 212902
Halo
84 K100RS 0014803
93 FZR1000 EXUP
View previous topic View next topic Back to top  Message [Page 8 of 21]
