202 Re: My 84 K100 RS restoration Thu Jul 26, 2012 7:12 am
Crap.
I am going to stop posting pictures now. Between you and Alex I am just happy my bike is clean(er).
Nice work Halo
Nice work Halo
203 Re: My 84 K100 RS restoration Thu Jul 26, 2012 8:51 am
hi mate ... i have a 16 spline shaft pinion bevel box to rebuild ....and it kinda sceares me ....but i think i have nothing to lose as its been moving fore and aft ...from before i got it ... the actuall bmw service handbook goes a long way to explain how and why ...whilst the haines just says ... steer clear
about the gear box ...i definatly would be putting in the seals at a minimum
i have noticed that the input shaft bearings seem to take a real load as the clutch plate does its job ... judging from others work..
204 Re: My 84 K100 RS restoration Thu Jul 26, 2012 9:06 am
twincarb
Hey Halo,
Good to see that the weather is now allowing you the time to work on the bike... Have a peek in the How to section and you will see my photo thread on the gearbox. I replaced all of the seals apart from one They are easy to do. and you know what sod's law says especially as you have the kit in your hands!
Twincarb
Twincarb
BMW K100LT 1988
Yamaha Thundercat
205 Re: My 84 K100 RS restoration Thu Jul 26, 2012 1:42 pm
Halo
Thanks Charlie & twin carb for your advice well as usual with this forum good advice is always present. Yes as a minimum l will do the seals, really good to know twin carb you have tackled this I will check out your thread today. Yes the weather has been really cold here this winter and the shed has been anything but warm but I am working on that. Charlie I better check out that bearing as well, and thanks for the heads up with the BMW manual will look and advise twincarb have you touched the final drive pinion gear?.
Rossco your doing a great job keep it up
Halo
Halo
84 K100RS 0014803
93 FZR1000 EXUP
206 Re: My 84 K100 RS restoration Thu Jul 26, 2012 6:03 pm
twincarb
I haven't had to do any work on the pinion gear, I stripped it down for a visual but everything looked good to me
BMW K100LT 1988
Yamaha Thundercat
207 Re: My 84 K100 RS restoration Fri Jul 27, 2012 5:19 am
Halo
Twin carb hood write up on the gearbox great work that should make it easier for me to do on Saturday. I will strip the box down first so it's easier to soda blast the cases
Halo
Halo
84 K100RS 0014803
93 FZR1000 EXUP
208 Re: My 84 K100 RS restoration Fri Jul 27, 2012 5:58 am
twincarb
It doesn't take to long to put it all back together, I seem to recall it was a little over an hour and that was with taking all the photo's as well....
I had my gearbox cleaned but wasn't happy with the final result so I have since painted it black!
Hope you get some heating sorted in your workshop soon...
BMW K100LT 1988
Yamaha Thundercat
209 Re: My 84 K100 RS restoration Fri Jul 27, 2012 9:21 am
Halo
Yes twincarb the initial warmth was found in a bottle of Jameson and I pick up a reverse cycle inverter airconditioner this weekend. I have prept the final drive for soda blasting tom (first clean) and I pulled the gearbox apart tonight after the general consenses was to open her up. Had some real trouble with the idler saft as she wouldnt let go, I heated it up in the end and she came out. Now the cases are ready for soda tom as well then seals
84 K100RS 0014803
93 FZR1000 EXUP
210 Re: My 84 K100 RS restoration Fri Jul 27, 2012 7:27 pm
twincarb
I am trying to remember if I popped the Black breather cap off of my final drive before I cleaned it all up! as otherwise you end up with soda caught under it....
I stripped it apart and dropped the whole unit into a hot bowl of water and washing up liquid to clean it up after. before giving it a good dry with compressed air...
BMW K100LT 1988
Yamaha Thundercat
211 Re: My 84 K100 RS restoration Sat Jul 28, 2012 2:55 am
Halo
Well twincarb I did block the FD breather hole thanks, the cleaning took about 6 hours and ended up being a combination of degreaser first soda blasting second, stealwool, brass brush and soapy water then paint prep.
Now its KBS clear spray time 2 days to dry then seals and complete drive train assy on the bench during the week with a bit of luck
Halo
Halo
84 K100RS 0014803
93 FZR1000 EXUP
212 Re: My 84 K100 RS restoration Sat Jul 28, 2012 7:17 am
Um...guys.
I can see a problem coming up.
When Halo comes on rides with us, will he be forced to ride a few kilometers behind, because his bike will make ours look like rat bikes?
213 Re: My 84 K100 RS restoration Sat Jul 28, 2012 7:54 am
twincarb
I didn't read anywhere that Halo was going to intend riding the bike hehe
BMW K100LT 1988
Yamaha Thundercat
214 Re: My 84 K100 RS restoration Sat Jul 28, 2012 8:21 am
blakey wrote:Um...guys.
oh crap ....ill have to fake a
215 Re: My 84 K100 RS restoration Sat Jul 28, 2012 7:07 pm
Halo
You guys seriously what do you mean ride it, l thought this was a 1:1 model kit that after you build you put on the shelf With the other ones.
With respect to Charlies comment about rs & rt all l will say is if you look at the forum header which k100 bike type is able to lean over further hey hey
84 K100RS 0014803
93 FZR1000 EXUP
216 Re: My 84 K100 RS restoration Sat Jul 28, 2012 9:29 pm
It aint leanin over it's fallin over.
217 Re: My 84 K100 RS restoration Sat Jul 28, 2012 10:20 pm
its all good halo ,,,,
btw they all lean the same amount, till the crankcases grind ....
done that on the way down the hill to areluen
218 Re: My 84 K100 RS restoration Sat Jul 28, 2012 10:36 pm
Halo
84 K100RS 0014803
93 FZR1000 EXUP
219 Re: My 84 K100 RS restoration Sat Jul 28, 2012 11:00 pm
That's just clear spray???????????? man that's good work
220 Re: My 84 K100 RS restoration Sat Jul 28, 2012 11:26 pm
super cool look halo ...drools ...
221 Re: My 84 K100 RS restoration Sat Jul 28, 2012 11:30 pm
Halo
Thanks K75 its a KBS paint that's more like 2 pack l have a speel about it a couple of thread pages back
Halo
Halo
84 K100RS 0014803
93 FZR1000 EXUP
222 Re: My 84 K100 RS restoration Sat Jul 28, 2012 11:34 pm
Lookin good Halo !
88....May contain nuts!
K75RTP - 1994
223 Re: My 84 K100 RS restoration Sat Jul 28, 2012 11:46 pm
Halo
84 K100RS 0014803
93 FZR1000 EXUP
224 Re: My 84 K100 RS restoration Sun Jul 29, 2012 12:57 am
such a shame really ...just spent a couple of hours trying to wash off about 4000 ks of road grime ...ya get that .on the big jobs !
225 Re: My 84 K100 RS restoration Sun Jul 29, 2012 6:29 am
Halo
Yes I know Charlie you get road grime and my bike in bits gets shed dust it's almost the same thing isn't it
Halo
Halo
84 K100RS 0014803
93 FZR1000 EXUP
226 Re: My 84 K100 RS restoration Mon Jul 30, 2012 8:37 am
Halo
Replaced the seals in the gearbox tonight and damaged the seal on the shaft to the clutch housing, stupid really I wasn't thinking. Will get one from BMW shop tomorrow, the backing of the neutral switch fell apart in my hands what's the go there? .
Halo
Halo
84 K100RS 0014803
93 FZR1000 EXUP
227 Re: My 84 K100 RS restoration Mon Jul 30, 2012 9:13 am
I had one do that on the K75 and ended up covering the back of the thing in sika flex and two years down the track it still works.
228 Re: My 84 K100 RS restoration Mon Jul 30, 2012 9:36 am
Halo
Yes Rick G it sounds like the go for me as well the switch still looks ok however I will test I think some sika flex will work but l will build a bit of a mold around it first.
Halo
Halo
84 K100RS 0014803
93 FZR1000 EXUP
229 two steps forward one step back Tue Jul 31, 2012 9:22 am
Halo
Finished off the gearbox tonight after going to my local BMW bike shop and getting another seal, It was then that I stripped the last bolt on the gearbox reco the one for the neutral switch that holds the ball & spring. I checked the torque setting in the manual several times and made sure I was refering to the correct part as it felt tight and stripped it, any ideas please guys?.
84 K100RS 0014803
93 FZR1000 EXUP
230 Re: My 84 K100 RS restoration Tue Jul 31, 2012 9:34 am
84 K100RS 0014803
93 FZR1000 EXUP
231 Re: My 84 K100 RS restoration Tue Jul 31, 2012 10:56 am
Either a helicoil ot tap it out to 10mm and get a 10mm bolt the correct length.
232 Re: My 84 K100 RS restoration Tue Jul 31, 2012 11:06 am
Halo wrote:.... made sure I was refering to the correct part as it felt tight and stripped it, any ideas please guys?.
Here's my technique:
Curse, swear, Shake your fist at it....threathen it with a box of matches and a gallon of petrol, walk away, breathe deeply and repeat, calm down...walk back in, reassess. Await someone's advice more technical than mine
Seiously tho' the best success I've had with stripped threads have been with an epxoy putty Called Devcon, It's a chemical steel and can be drilled, machined and tapped once hardened. I've redone an exhaust stud socket with it and clamped up tight not to mention numerous other repairs. Rick G told me he repaired a crankcase the had been pierced by a conrod with the same stuff. It's expensive but very good.
The FD and all cleaned up beauty, how do you get them so clean? REALLY impressive work Halo.
Ammendment to post: Rick G's been typing at the same time as me! just seen the picture again..tap it out to the larger size looks easiest. - Make sure it's properly centered.
Last edited by 88KE on Tue Jul 31, 2012 11:12 am; edited 1 time in total (Reason for editing : ammending input)
K75RTP - 1994
233 Re: My 84 K100 RS restoration Tue Jul 31, 2012 7:56 pm
Halo
Thanks Rick G & 88KE I have never used helicolls etc I was hoping I didn't have to open the case again but anyway. 88KE it's all just patients and elbo grease, thanks for the complement though keeps me going.
Halo
Halo
84 K100RS 0014803
93 FZR1000 EXUP
234 Re: My 84 K100 RS restoration Sat Aug 04, 2012 8:01 am
Halo
84 K100RS 0014803
93 FZR1000 EXUP
235 Re: My 84 K100 RS restoration Sat Aug 04, 2012 9:38 am
wow what a sight halo
onya mate !
onya mate !
236 Re: My 84 K100 RS restoration Sun Aug 05, 2012 3:26 am
Halo
84 K100RS 0014803
93 FZR1000 EXUP
237 Re: My 84 K100 RS restoration Sun Aug 05, 2012 3:38 am
Hmmmm That bumper spray should work on my givi panniers. Worth a try
238 Re: My 84 K100 RS restoration Sun Aug 05, 2012 3:52 am
Halo
Yes Rick G worth a shot I will update photos during the week, I never marked the clutch plates up any ideas ?
Halo
Halo
84 K100RS 0014803
93 FZR1000 EXUP
239 Re: My 84 K100 RS restoration Sun Aug 05, 2012 4:40 am
Just put them back in. I have done it a few times without any problem. I can not make any real sense out of the ballance marks and drill holes to remove metal.
My theory is that they are all ballance individually and then asembled and checked and if by chance the margins add up to a slight out of ballance then they change it.
You don't need to buy them as a set
240 Re: My 84 K100 RS restoration Sun Aug 05, 2012 5:22 am
Halo
Yes my thoughts exactly why would they have individual balance marks if they were not balanced individually? Still should have marked it.
84 K100RS 0014803
93 FZR1000 EXUP
241 Re: My 84 K100 RS restoration Sun Aug 05, 2012 5:30 am
if there are any marks at all ....i think i read a bulletin that says , assemble any marks 120 degrees apart ..
good luck halo mate !!!
242 Re: My 84 K100 RS restoration Sun Aug 05, 2012 5:36 am
Halo
Yes 120 degrees all marks were sans blasted off just don't know when to stop with that machine
84 K100RS 0014803
93 FZR1000 EXUP
243 Re: My 84 K100 RS restoration Sun Aug 05, 2012 5:54 am
ill send you a cold chisel then ???? throw that brush away ....giggles
244 Re: My 84 K100 RS restoration Sun Aug 05, 2012 6:15 am
Each of the clutch parts is marked at their heaviest spot.
By mounting them 120 degree apart, they all pointing in different directions.
A metod I did read about somewhere, was to put a tennis ball or similar at the center and place it on a table.
Then move the different parts around, to find the best balance point.
Newer tested this............
245 Re: My 84 K100 RS restoration Sun Aug 05, 2012 7:18 am
Halo
Inge K sounds worth trying I will tell you how it goes, I ordered the helicoil M10 kit on ebay comming from England.
84 K100RS 0014803
93 FZR1000 EXUP
246 Re: My 84 K100 RS restoration Mon Aug 06, 2012 5:10 am
Erman
Awesome work, Halo. The blasting + clear coat looks stunning. I have an airhead on the side, where I painted the engine with Bill Hersch engine enamel. Would the fact that the K100 engine is water cooled eliminate the need for using paints and clear coats suited to better dissipate heat?
I was wondering if you have a picture of the crankcase from the right? Eventually, I need to take this off and put new sealant in, and a fresh pic would certainly help. Also, what are you using for sealant between case parts (apart from the obvious ready-made gaskets)?
Erman
Erman
Bikes:
1984 BMW K1000RS
1984 Yamaha XJ750 Seca
247 Re: My 84 K100 RS restoration Mon Aug 06, 2012 8:30 am
Halo
Hi Erman, they tell me that the spray paints do affect the heat dissapation as even though it's water cooled they rely on the radial fins on the sump to dissapate heat as well the power coating process being the worst, you could use acrylic black or clear, I use a KBS system as explained in few pages back. Heres the picture you wanted I hope this helps.
The case sealent I use is this one, purchased from motobins in the UK but no doubt you could source locally
84 K100RS 0014803
93 FZR1000 EXUP
248 Spray painting plastic parts Mon Aug 06, 2012 8:50 am
Halo
I was keen to try spraying the plastic parts now that I'm starting to put the old girl back together. I found some deep marks were the TBS airbox was siting under the fairing, I sanded these out with water and detergent with 300 wet & dry onwards.
Then applied the bumper primer 2 coats
Then the top coat bumper spray 2 coats. It came out more diffused than to my liking but looks better than before. Will do the airbox next.
Halo
Halo
84 K100RS 0014803
93 FZR1000 EXUP
249 Re: My 84 K100 RS restoration Mon Aug 06, 2012 8:57 am
Wow I can feel a panier painting comming on here.
250 Re: My 84 K100 RS restoration Mon Aug 06, 2012 9:10 am
Halo
Yes I must buy a scratched up set and try that would be a good project
84 K100RS 0014803
93 FZR1000 EXUP
251 Re: My 84 K100 RS restoration Mon Aug 06, 2012 9:11 am
Halo
Look back last Page for latest photos
84 K100RS 0014803
93 FZR1000 EXUP
Similar topics
