51 Re: Output Shaft Inspection Tue Aug 23, 2011 7:46 pm
ReneZ
No worries Mate, 'I fight my own battles where and when I choose'.......
(Note John Wayne voice ;-))
Go to page : 1, 2
hot_seat wrote:well i got the bike apart today and found the spline for the final drive is shot,so i ask the profesionals (you guys) what are my options i need to renew both male and f/m i hope i don't have to get a new drive shaft and drive pinion as i may have to go see the bank manager,can i get a rebuild somewhere??
Last edited by K Freak on Sat Aug 27, 2011 5:02 am; edited 1 time in total (Reason for editing : more rubbarb)
ReneZ wrote:@ K Freak - I think he has the 'one-part-shaft' on this early bike, which normally goes first at the aft end. He is mentioning the FD side.
hot_seat wrote:thanks K,another ?? those stupid low head torx screws that are on the clutch housing (stupid idea)i rounded 6 off and had to drill them out ,is there and reason i carn't replace with normal alen key heads ?
hot_seat wrote:there is so much room in the back space of the bell why do they use a low profile head ??
Perhaps they don't want to disturb the boundary layer and increase the air drag over the clutch, cause this will cause a loss of torque and power...?hot_seat wrote:there is so much room in the back space of the bell why do they use a low profile head ??
hot_seat wrote:And another ???? the engine cover over the timing chain ,on the left hand side is some sort of switch ,is that a engine cut out incase the chaine breaks or what is the little beastie i carn't find it in Haynes
Go to page : 1, 2
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Output Shaft Inspection
Similar topics
