1 output shaft questions Wed Dec 18, 2019 2:44 pm
audibob
I do not have any rattles, tapping, hot or cold. just an annoyingly heavy buzz sound from the front of the bike.
Listening to the water / oil pump housing and the cam cover at cylinder number 4 via a long screwdriver
confirms the source of the noise.
I have some questions
1. Does anyone know if the later k1100 units ever suffered from loose rivets.
2. Forum member " The Mason " mentioned that removal of the anti backlash gear, completely eliminated
the " K100 drone" from the engine, but did allow a little noise at tickover . Has anyone done this?
3. Would this allow damage to the main gear without the backlash facility.
4. Did the 12 rivet unit suffer from the backlash gear spring failure I see from the early type.
I changed the cam chain because I thought it was the noise I was hearing.
Best thing with this bike is easy access to a lot of the major components.
Am looking forward to a quiet bike again soon..
Right..xmas shopping list for my other half, forget the usual stuff, this is important.....
12 rivet unit , probably ..I am not normally that lucky
Output shaft bearings, shims, circlip etc
Damper rubbers
Intermediate housing bearing
Gearbox seal
anything else anyone ?
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
