1 K100RT Intermediate Gear Repair Thread Sun Jun 26, 2011 11:17 pm
Hi,
Rather than hijack the other thread I started about the K1100 overflow tank, I thought it better that I start a new thread dedicated to my intermediate gear repair. At least, at this point in time, I THINK it is the intermediate gear in the bell housing that has been trashed.
First, a little history. I did an alternator swap a couple weeks back. The new alternator had the coupling adapter too high in the shaft, which pushed the drive dog causing it to bind on the bell housing. The result was a catastrophic failure of something in the bell housing. I am guessing at this point that it is the intermediate gear...I might be wrong.
Fast forward to the present. This weekend I started the strip down to get at the bell housing. I encountered a delay in the stripdown. Seems one of the bolts holding the transmission to the clutch housing is siezed. I'm waiting for tomorrow (Monday) to get an impact driver to release the bolt and continue the disassembly.
Quote from the other thread...
As you can see, the transmission is most readily removable. BTW, you might just be able to pick out the set of "outriggers" that I built which bolt to the oil pan and which stabilizes the engine on the motorcycle jack. They work very well. They are just a couple lengths of 2" angle iron. The remainder of the bike is on the other side of the garage...
As an asside, the bolt that is giving me grief at the moment is pictured below. It's the one in the centre of the photo ...
So, I'll use this thread to post progress reports and ask specific questions. I'm sure there will be a few because, for me, this is very scary work. I've never before in my life attempted a repair of this magnitude. So, I'm nervous but also excited to learn new things about the mechanics of the bike.
Thanks for viewing.
Well, I don't think I'll have ANY problems moving the trans out of the way. This is the bike at the moment...I have had some like that where I have drilled the head of the bolt and then work on it without the trans in the way It's not always possible as you may not be able to move the trans back far enough to clear the remainder of the bolt.
Thanks for viewing.
