1Back to top Go down   Bevel Gear repair Empty Bevel Gear repair Fri Aug 12, 2011 7:35 am
twincarb
twincarb
Just in the process of taking the Bevel Gear apart so i can get the splines repaired, has anyone taken theirs out and got any advice on the best way forward, Haynes basically says RUN AWAY>>>>> Bevel Gear repair 259495
2Back to top Go down   Bevel Gear repair Empty Re: Bevel Gear repair Fri Aug 12, 2011 8:01 am
twincarb
twincarb
I think i have found the answer myself within the Clymer manual.... now just to read it a couple of times and then adapt it to not having the BMW jigs....
Yamaha Thundercat
Bevel Gear repair 169042Bevel Gear repair 169034
3Back to top Go down   Bevel Gear repair Empty Re: Bevel Gear repair Fri Aug 12, 2011 10:49 am
Getting those splines repaired will be a very expensive operation. I would only attempt it if I had no option and there was no way I could replace with a new or secondhand.
I would just get a secondhand rear drive in good condition and replace the seal and O ring which is very easy to do.
4Back to top Go down   Bevel Gear repair Empty Re: Bevel Gear repair Fri Aug 12, 2011 11:06 am
twincarb
twincarb
I have just spoken to my local mechanic who took a look at the bevel drive, he reckons that it's ok, but to replace the driveshaft end of it, and keep it lubed properly.
I am keeping an eye on ebay for a replacement but there is nothing that i can see at the moment...
Yamaha Thundercat
5Back to top Go down   Bevel Gear repair Empty Re: Bevel Gear repair Fri Aug 12, 2011 5:25 pm
hey twincarb ...someone .(i think motobins ) does a replacement ferule/spline for the end of the shaft .
basically you machine the end off and reweld the new part on .....just be carefull doing this, i bought a reworked one and found it to be about 5mm too long ...basically it was hitting the pinion nut in the bevel box .....so being a real nutter ....got out the angle grinder and hacked off the excess...its been good for maybe 4,500 ks so far.
i can tell you the metal that is used is really tough stuff .
so like most things ....measure it all before ....whats that old rule ...."measure twice ....cut once"
6Back to top Go down   Bevel Gear repair Empty Re: Bevel Gear repair Fri Aug 12, 2011 6:14 pm
http://www.motobins.co.uk/displayprod.php?function=subs&subs=073&title=DRIVESHAFTS&model=
Here's the link to the 'Bins driveshaft page for K Bikes. You have to hunt round a bit there but it'll pop up. Click on the blue line that pertains. It shows the complete unit or the end bit you, or someone you trust, weld on.
But I think the phrase is supposed to be "a splash of wine for the food and two splashes for me"...or maybe that's why the driveshaft ended up being 5mm too long in the first place!?
7Back to top Go down   Bevel Gear repair Empty Re: Bevel Gear repair Fri Aug 12, 2011 7:18 pm
twincarb
twincarb
I saw the replacement splines on there and think thats the route that i am going to go down, I wouldnt trust my welding but there is a machine shop which is just down the road from work that i will get to do it for me.... I will measure the final length of the shaft before i take it in and then when it is returned!....
Better safe than sorry....
I am in work tonight, unfortunutly the company browser doestn like motobins site coding so cant put my order in tonight! hmmmmm Sad
next job is going to be getting the gearbox off the engine and have a look to see how it is holding out fingers crossed i will have a whole bike back together clean and working as it should do!
Any idea how close to the pinion nut the shaft reaches in normal use?
Yamaha Thundercat
8Back to top Go down   Bevel Gear repair Empty Re: Bevel Gear repair Fri Aug 12, 2011 7:23 pm
about 3-5mm when the angle of the shaft / swing arm is more or less horizontal (i guess thats the point when its the longest )
9Back to top Go down   Bevel Gear repair Empty Re: Bevel Gear repair Fri Aug 12, 2011 7:27 pm
twincarb
twincarb
once i get the splines from motobins will check that there isnt excessive play on the bevel drive when it's mated together... oh why oh why didnt BMW opt for a wet design lol!!!
Yamaha Thundercat
