The custom R100's master cylinder bore is 16mm (R65) which gives a reasonable feel at the lever (with just a red pube more travel than I like) but which provides stoppie-like braking power on the olde girl with those later Brembo 4-piston calipers and K75S 'S' forks. The metal of the Suzuki discs must be of a high enough grade because it works well. The bike has good brakes compared to anything from BMW of the early dayz - it's a '77/'91 hybrid, I bought the 1977 new, it's a real bitsa. I don't know which model Zooki the discs came from as I obtained a few sets of them from a former BMW dealership work colleague who was a club racer who used them with special multi-piston calipers on his rarefied Airhead. He raced it in an American/Pacific Northwest series ten, maybe fifteen years ago. He's the one who fabricated those aluminium spacers that centre the discs right in the middle of the caliper.
There's a chart out there floating round the internet which purports to show the correct ratio master cylinder to caliper piston size. It's reasonably accurate in the ratios I've attempted on various bikes. But, I note that later K100 and all K1100 series, with or without ABS, used a 20mm bore and yet the later Airheads used a similar 4-piston caliper with a 12 or 13mm master cylinder. I don't currently have a 20mm master cylinder to try, only a 12 and a 13mm bore version, for when I do the deed to my K100RS.
One other thing that really helped when putting together the Airhead's set-up was a set of high-quality HEL stainless steel braided hydraulic lines made locally near Brisbane. It's one thing to get a bike going, we all enjoy that, and another thing entirely to yell 'whoa' and get some results.
