tinyspuds
tinyspuds
Morning all,
I have just rebuilt all three single pot non-ABS calipers to install new seals.
Although my outfit has leading links, AFAIK the front splitter is as per standard. However, PO had fitted stainless lines. I noticed when I took the calipers off that the fitting nut did not rotate on the lines and I had to rotate the caliper to unscrew it from the fitting.
That didn’t seem right and at the time I thought I would take care of it at refit but no matter what I tried I couldn’t get any movement of the fitting nuts relative to the lines at either the caliper or splitter ends.
That’s when my stupid took over. I decided that must just be the way SS lines work, put it all back together, flushed and bled the fluid during which process I had to put more than an extra half turn to the RH fitting nut to get it airtight. Naturally this has put a gentle half spiral into the brake line.
Bleeding the system was such a pain that I’m tempted to just dismount the caliper and rotate it the other way to get the spiral out of the line.
This isn’t right is it?
Something should be freely rotating, yes?
The tension in the line will create a tendency to unscrew the fitting until the stress is relieved? (I used a touch of copperslip at the caliper fitting so this is relatively low friction).
Am I going to die?
I’ll take the existential feedback too, but I have cocked up haven’t I?
Cheers, Stu
Suzi Q
Suzi Q
That's a 'normal' thing with aftermarket stainless lines. If you've got the type with nuts and olives, that is.
When the lines are being made up you can usually keep on tightening the nuts until things line up. If that doesn't work, it's possible to take it apart and tap the nut back up the line so's it's free, and have another go. A little bit of oil on assembly helps.
That might not be much help to you if you've got oldish fittings.
The proper solution is to design the line with swivel joints. This is more expensive (it usually involves an extra fitting) and so doesn't often get done.
Below are the Oohbay item numbers for a swivel fitting, and the M10x1.0mm adaptor that screws into the caliper port, the swivel fittings also come in 45 & 90 degree variants for where a banjo might be chosen. Alternatively (if you're replacing a banjo that is) you could use a a banjo with a M10 flare end, and screw a M10 straight swivel onto that.
370992908166 371084490251
Bear in mind that a lot of people quite correctly call against doing this sort of stuff. Manufacturers are unwilling to approve products for brake usage too. All I can say is that I've been making brake lines like this for years without a single issue. If you're not sure, don't guess.
tinyspuds
tinyspuds
Thanks Chris,
Nice to hear that I haven’t completely missed the obvs.
Currently the caliper port has a banjo:
front calipers and stainless line refit 3ab58a10
I assume that I can use one straight to replace the banjo, one swivel joint, and either another straight or re use the banjo between the swivel and line. Will solve my problem, but do you imagine I could leave the existing banjo in place, connect the locking end of the swivel and take the non-locking end nut off the swivel for direct connect to the line?
Trying to save on joints rather than costs, cos brakes is brakes; just really pleased to hear there is a solution out there somewhere, so thanks again.
You'll need new -3 (dash 3) series olives:
https://www.ebay.co.uk/itm/Banjo-Olives-Per-5/113713263302?hash=item1a79d6b2c6:g:iV4AAOSw02FcrNd3&frcectupt=true
IMO that price is a bloody ripoff but I couldn't find anything cheaper. I also use Dowty washers rather than copper crush washers:
https://www.ebay.co.uk/itm/Metric-Bonded-Seal-Washers-Dowty-Sealing-Washer-Sealing-Washers-M10-M24/123082283886?hash=item1ca8469b6e:m:mJmDrN6FISSUe2pmx47rK8A&frcectupt=true
They're more tolerant of re-use and of not being tightened up enough. Better still, if you find yourself in the position where you've made a brakeline with a banjo on one end and a direct fitting into the caliper on the other but there's a twist in the line when everything's tightened up, you can use two washers side by side to relieve the unwanted angle. This is heresy! Heresy, I tell you! But I've been doing it for years with never a failure yet.
tinyspuds
tinyspuds
Thanks Dai
Stu
I don't know what lines you have, but in the U.S. Spieglers are very common and that is what I have on my bikes.
The Spieglers come with three pieces of plastic.  Two form a clamp around the end of the line when you clamp it in a vise, and the third is a rod that fits into the banjo fitting and is used to turn the banjo in relation to the line.  They allow the user to fine tune the end of the cable to exactly the angle that's needed.   The fact that the fitting is hard to move allows it to hold the angle you set it to.
If you have the type of ends used by Spiegler you could make the clamp by drilling a hole in a 1cm thick piece of plastic about 3cm x 6cm and then cutting the piece in half.  A piece of brass rod that is a snug fit in the banjo can be used to turn it.
tinyspuds
tinyspuds
Thanks .75
Stu
tinyspuds
tinyspuds
Update. Thanks all. You’ve given me enough to think about and I will rotate the caliper for now.
I suspect the braided lines pre-date the leading links (where the calipers hang from the swing arm) and even if they are not from the original teles they feel a bit skimpy in length. At some point I will either buy or make some slightly longer lines with new joints (hopefully with just a male/female swivel on each side) and do it proper. In the meantime I will keep a close watch on the banjos for loosening/leaking.
But right now I want to ride.
Cheers, Stu
Update. Assuming there are others out there who, like me, have only understood every other word of the foregoing here’s a really useful link that shows how it’s done:
https://www.motamec.com/info/instructions_brake_hose_fittings/
Last edited by tinyspuds on Thu May 09, 2019 10:04 pm; edited 1 time in total (Reason for editing : added tutorial link)
tinyspuds
tinyspuds
It seems as though PO thought washers on the banjos was a bit upmarket too.
I’ve test fitted the swivels and it looks like the extra couple of cm plus the ability to rotate the lines is enough to take the tautness out.  I’ve also tried out the straight connector in place of the caliper banjo. Tidy, but prefer the extra smidge of tyre clearance afforded by the banjos, so they will be going back on as soon as my Dowty’s arrive.
Oddly enough, I made two new brakelines today too, direct from the calipers to a double banjo on the master cylinder.
tinyspuds
tinyspuds
As I don’t know yet how successful I will be at getting the old olives out without losing more length from the line, I am also considering replacing the whole run (esp as I now have fittings, dowty washers and olives coming out my ears).
What brake line do you use? And do you think it’s a worthwhile exercise for an amateur or should I just go to Venhill’s ‘line builder’?
Ah, right. Sometime back (quite a while back) someone was selling off stock of Goodridge brake hose for £2.50 a metre. Not being one to miss a bargain, I bought ten metres of black, twenty metres of translucent and ten metres of blue (why???). I did resist the temptation to buy some Kawasaki green.
IMO the problem with Venhill's line builder is that if you get the measurements wrong, you're left with an unusable length of brake hose. At least with the do-it-from-scratch method the buggered length can be shortened and used for something else, until you cut it too short Twisted Evil
One thing I've never really seen explained in any of those videos is how to get the front lengths right. Extend the suspension to full extent (dunno what you'd do - I just stick a big block of wood under my engine), then make up one end of the hose. Screw/bolt that to the bike as if it was finished, then run the hose to the other end. I started with the calipers and worked up to the master cylinder. I put the banjo on the master cylinder and brough the hose up to the fitting point, allowing a very small amount of slack. I do mean 'small' - it wants to be just on the right side of tight because once the suspension hits the floor that slack is going to increase and you don't want floppy brake hoses.
I'm definately an amateur. I just refuse to pay for someone to do something for me if I have the time and can do it myself. Mind you, after I'd made the very first one (a rear brake hose for my Guzzi G5) I shit bricks for miles until I was sure I'd got it right!!! front calipers and stainless line refit 44271
tinyspuds
tinyspuds
Echo  front calipers and stainless line refit 44271 . For two reasons: I have absolutely no idea if I am competent to do the job, and b) because since posting I have ordered 2 metres of ss line and the fancy little fittings vice. See you in Snowdonia or K heaven  front calipers and stainless line refit 44271.
For anyone else interested in this stuff, leading links seem like tricky little sods as the calipers are under the swing arm with hose and bleed fittings pointed at the ground (on a trajectory that passes through the outside edge of the tyre). The swingarm rises up under braking and takes the caliper through quite an arc. My existing lines are 630mm long   and working but feel a bit skimped and limit routing options, so I’ll add 20 or 30mil using the approach you describe #fingerscrossedandbuttocksclenched emoji.
Suzi Q
Suzi Q
"You do realise that when you tell me to do s**t I just do it, right? Anyone need any swivels?  front calipers and stainless line refit 44271."
Yep, I did think of you/this thread when I went and made my brake line!
Fronts are different though. I'll see if I can post some pics of a trike leading links later on, also some ideas that might help. Hose routing is worth spending some time on otherwise you risk stretching things if you top out over a bump (done that!) or snagging passers-by with an excessively big loop of hose (not done that yet, but there's always hope). The MOT tester that I trouble with my creations is very 'practical', but brake hoses have to be spot on.
Re. length: hose is relatively cheap so guess long and just dry assemble it (no olive - just slip the hose end onto the fitting barb and see how things are looking)
Take care with flaring the braid - make sure no strands are trapped between the olive and the ptfe. If you have a dremel, the thin cutting discs make a really neat job of cutting the hose - the last thing you want is ragged braiding, it makes it difficult to get the nut on, plus it hurts like hell when it sticks in your fingers.
tinyspuds
tinyspuds
It turned out my existing lines HAD swivels mounted up at the splitter (I didn’t know what I was looking for and they were seized solid) looking forward to fitting my new stainless ones when my Gold! hose arrives from Goodridge. In the meantime I will practice cutting and olive-ing on the old lines.
As I mentioned above, I’ll use my existing line length as a minimum as I know that works and add an inch or so to give me some routing room around the forkleg/swing arm junction as that’s where I think there is a risk of chafing against bolt heads/mudguards et al. Must admit I hadn’t thought of MOT complications so I’ll review examples online to make sure I don’t own goal.
PS. I too have never snagged a passerby with loopy brakelines, but when I was furnishing my first flat I carried a 10’ rug rolled up on my Triumph pillion seat and did a Boudica down the highstreet before I realized it was me the people on the pavement were shouting at
(o)(o)(o)(o)
Yes we heard about that........
when you went kayaking.....
front calipers and stainless line refit Bbgry010
Suzi Q
Suzi Q
Here's one I made (much) earlier. Sadly, my welding hasn't improved over the years since.
Calipers are BMW K100 too, oddly enough.
Actually, the front shocks are BMW K100 rear as well!
front calipers and stainless line refit 00214
tinyspuds
tinyspuds
Thanks guys. Goodridge hoses made up and tested yesterday. I left them overnight with the lever taped back to try and get those last few bubbles out but I was able to lock up the front a number of times at 15 to 20 mph and the joints held/remained dry.
By adding another 10cm to the original length I was able to get a nice gentle loop around the leading link pivot away from all the moving parts.
Suzi Q
Suzi Q
Result!
And that's your first attempt  cheers
Pucker factor on the first ride?
tinyspuds
tinyspuds
I had every confidence in my two coaches  front calipers and stainless line refit 212902 .
Probably less scary on an outfit than a solo but overall I would still feel more confident if there were specs available for the tightness of the olive-d nuts. I read all the stuff about marking and counting flats and other approaches to ensuring ‘not too tight and not too loose’ but for me any metric that starts with ‘get it finger tight and then...’ is never going to reassure.
Used my instincts and guess I just got lucky, assuming that if they didn’t fail yesterday or leak today then we’re probably ok.
Have to say it was a very satisfying job and at first glance I think it’s better than I found it (which I can’t say about everything I ‘improve’).
front calipers and stainless line refit Ec6d9e10
moriarti
moriarti
My K is still on original brake lines so how much of an improvement in breaking is achieved by
fitting the new lines
moriarti wrote:My K is still on original brake lines so how much of an improvement in breaking is achieved by
You will get an increase in stopping power per unit of lever pressure, along with a more positive feel in the lever when the sponginess of the old rubber lines is eliminated.
moriarti
moriarti
Thanks for that,another job on The Todo List study
tinyspuds
tinyspuds
Can’t say for sure on the K as I was replacing badly fitted braided.  But I would have thought that 35 years old lines were probably EOL anyway?
I have made the update to ss lines on a number of other bikes tho and they always stopped better and felt crisper. This was my first time making up my own lines and it was very rewarding and not too difficult (all the usual disclaimers apply).
