1Back to top Go down   torque value for output shaft 86  k100 Empty torque value for output shaft 86 k100 Sat May 21, 2011 11:30 am
yankeeone
Hi my clymers book has no torque value for the big bolts, on the out put shaft, on the motor I need both ends.
Brian
ReneZ
ReneZ
Sorry Mate, don't understand which ones you're talking about. Put a picture or a drawing from realoem in your post?
Rene
BMW K100 - 1985 (0030029) Scotland torque value for output shaft 86  k100 Rain
yankeeone
All set back together and running
Brian
4Back to top Go down   torque value for output shaft 86  k100 Empty output shaft torque Tue May 01, 2012 12:17 pm
jeffeaby
jeffeaby
i am at the same place...what are the bearing torque values?
yankeeone
I was there to , with the locktite on, an no torque value for the bolts, had to run in and google it. not listed in the Clymers.
just realized that was me!!!
jeffeaby
jeffeaby
so what's the answer!!!!~can't find it on google
Being a bit more specific, would have done it easier to give an answer.
yankeeone
yankeeone
Jeff, did the outputshaft workout ?
jeffeaby
jeffeaby
thanks, your link had a value of 40 ft-lbs...seems right, was a bear to take off. assembly will be sometime next week. can't wait to get the bebuild going.
yankeeone
that baby is in there pretty deep, good luck, go slow when you put it back, I set the wrench to the wrong torque, but caught it in time.
jeffeaby
jeffeaby
thanks for your replies, yankeeone. did you replace the bearings while you had the shaft out? only about 110$ so seems a good thing to do. have replaced every seal and piece of rubber so far..getting costly
yankeeone
I had to change over the big bearing any way because my block was old style I did switch to a new one but the old style was only 35.00
the output shaft I bought was in really good shape
so I didn't replace the rear bearing.
yankeeone
I see there is a new link for the output shaft above, it calls for 29ft pounds on those bolts, the 40 you quote is nms
