1Back to top Go down   Liqui-Moly LM 47 Empty Liqui-Moly LM 47 Sun May 06, 2012 5:32 am
Lazyboy
Lazyboy
Is there any one that has info on Liqui-Moly LM 47 ? Percentage MoS2 ? It is available in South Africa and could it be used for Spline Lube ?
1984 BMW K100RT
Bikes Name: Lazyboy
2Back to top Go down   Liqui-Moly LM 47 Empty Re: Liqui-Moly LM 47 Sun May 06, 2012 10:09 pm
cruise_carter
cruise_carter
3Back to top Go down   Liqui-Moly LM 47 Empty Re: Liqui-Moly LM 47 Mon May 07, 2012 4:04 pm
Motobins supply LM47 as 'BMW specified' final drive spline lube, but if you ask 10 K experts, "What is the correct spline lube?" you will probably get 10 different answers!
I've always used LM47.
Cheers,
4Back to top Go down   Liqui-Moly LM 47 Empty Liqui-Moly LM 47 Tue May 08, 2012 5:20 pm
Lazyboy
Lazyboy
Thanks for the reply it is great to know that I can safely use Liqui-Moly LM 47 on the splines . I have found it in S.Africa and bought a 100grm tube for $4=50
1984 BMW K100RT
Bikes Name: Lazyboy
