1 Fork Seal Problem on a 1986 K100RT Tue Dec 02, 2008 5:10 am
beinn
I hope someone can help. I have just taken off the lower fork to replace the oil seal and it does not seem to be the same as the spares diagram or Haynes manual. After trying to lever the old seal out without success (excepting removing the oil scraper spring). I soaked it in hot water and then tried again. This time the main seal was soft and pretty much fell apart. Leaving a metal rim around the top of the forks and crud between the metal rim adn the seal seat.
This metal rim according to the manual should be a circlip/split ring. But it is solid and certainly does not want to move. Is this some old design not covered and how am I suposse to change the seal??? Any help appreaciated, ta
