Number of posts : 7967
Welcome to the forum from the northern territory.
That's a rather nice K.....so don't be afraid to ask any questions as someone will have answers for you.
A few items you can check easily...
Does the cooling fan come on?
Can you turn the blades by hand?
Does overheat warning light come on?
If fan comes on does it come on before or after the warning light?
The fans go wrong, particularly from lack of use and can seize.
Any signs of water or coolant leak? Or is coolant at correct level.
Down the road and depending on history you could potentially have a water pump issue but resolve other things first. Water pump usually shows up by way of coolant leak or coolant in the engine oil.
Due to age your fuel lines are likely gone hard and working on the bike now may well crack them. Replace them but go about 1 1/2" longer on the two at the front and you can then slide tank back to access coolant filler cap or to access the electrical relay box without disconnecting it.
1971 Yamaha 125 YAS-1
