1Back to top Go down   Fork seal leaking Empty Fork seal leaking Fri Apr 19, 2019 4:08 am
audibob
audibob
I recently changed a fork seal only to find the new one leaked, as did the second .
Everything was clean prior to fitting, I used cling film top of the leg to protect the new seal .
A seal driver tool was used to fit them.
Seal lube applied  but both leaked .
I then ordered a set from a different, well known uk  supplier, and this time all is good.
The seal from  the second set did feel more resistant when sliding it down the fork leg,
 both sets were marked 41.4mm , perhaps my bike prefers blue seals rather than black ones.
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
2Back to top Go down   Fork seal leaking Empty Re: Fork seal leaking Fri Apr 19, 2019 5:30 am
There was a certain brand of seal that was renown for leaking, I can't remember the brand. I've had my current seals for nearly twenty years. I fill under the dust cap with heavy silicone grease which seems to have worked and lengthened their life. I change the grease every couple of years or more often in dusty conditions. Other Brickers have had success with a tool called Seal Mate which can clean out any crud under the lip. you can save money and make one out of the side of a plastic soft drink bottle.
3Back to top Go down   Fork seal leaking Empty Re: Fork seal leaking Fri Apr 19, 2019 11:55 am
audibob wrote:I recently changed a fork seal only to find the new one leaked, as did the second . . . .  both sets were marked 41.4mm
Was it an OEM seal?
4Back to top Go down   Fork seal leaking Empty Fork seal leaking Fri Apr 19, 2019 2:58 pm
audibob
audibob
My tubes measure 41.4mm
My leaky black seals came from Motorworks,  the blue seals are from Motobins.
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
5Back to top Go down   Fork seal leaking Empty Re: Fork seal leaking Fri Apr 19, 2019 5:53 pm
audibob wrote:My tubes measure 41.4mm
That seems to be measurement alright.
6Back to top Go down   Fork seal leaking Empty Re: Fork seal leaking Mon Nov 16, 2020 8:01 am
Timos
Timos
I've recently recommissioned an old K100.
I replaced the fork seals (from Motorworks), and cleaned out the forks as a matter of course.
They leaked straight away. So I got another pair of seals from Motorworks, this time they were ok for a hundred miles or so, and now they are both leaking again.
I've not had a BM before, and it seems a bit strange that the seals aren't held in with a circlip or anything!
Are you saying seals from a different supplier may solve the problem.
I will add, that the fork legs are in good condition.
7Back to top Go down   Fork seal leaking Empty Re: Fork seal leaking Mon Nov 16, 2020 8:08 am
Measure the diameter of the forks they could be K75 which are 0.4mm smaller. As far as I know all the K100s had circlips.
8Back to top Go down   Fork seal leaking Empty Re: Fork seal leaking Mon Nov 16, 2020 8:22 am
Timos
Timos
RicK G wrote:Measure the diameter of the forks they could be K75 which are 0.4mm smaller. As far as I know all the K100s had circlips.
My fork legs measure 41.4mm
9Back to top Go down   Fork seal leaking Empty Re: Fork seal leaking Mon Nov 16, 2020 8:34 am
mike d
I believe the that the Fichtel & Sachs (K75C and K100 (not 4 valve) forks were 41.3mm diameter, and the later Showa forks K75 08/91 - 1996 were 41mm diameter.
Update: Looking at the MAXBMW parts list site, the snap ring to retain the seal was fitted from 09/87.
Mike
Last edited by mike d on Mon Nov 16, 2020 8:44 am; edited 1 time in total (Reason for editing : Added date when snap ring fitted.)
10Back to top Go down   Fork seal leaking Empty Re: Fork seal leaking Mon Nov 16, 2020 9:05 am
Timos
Timos
mike d wrote:I believe the that the Fichtel & Sachs (K75C and K100 (not 4 valve) forks were 41.3mm diameter, and the later Showa forks K75 08/91 - 1996 were 41mm diameter.
Mike
Thanks Mike.
Mine is an 84 K100RS, so it appears to be correct.
I just need to know if there is a 'better' make of seals for it. In the UK.
Tim
11Back to top Go down   Fork seal leaking Empty Re: Fork seal leaking Mon Nov 16, 2020 9:25 am
I use ATF in my forks. Cheaper than fork oil, and it has stuff that softens the seals a bit so they work better.
12Back to top Go down   Fork seal leaking Empty Re: Fork seal leaking Mon Nov 16, 2020 10:12 am
mike d
Were the seals from Motorworks OEM or pattern.
If pattern, I would look to buy genuine OEM seals.
Mike
13Back to top Go down   Fork seal leaking Empty Re: Fork seal leaking Mon Nov 16, 2020 2:20 pm
If you pack heavy silicone grease between the seal and the dust cover it will prolong the life of the seals. Clean and change the grease every couple of years. It stops road crap from getting down to the lips of the seals and keeps them lubed. I last changed my seals over 20 years ago. Silicone grease packed under the boot of your rear master cylinder will also extend it's life. It'll stop the ingress of water and road scum.
14Back to top Go down   Fork seal leaking Empty Re: Fork seal leaking Mon Nov 16, 2020 7:47 pm
I have had very limited success with any of the aftermarket seals but genuine OEM have always been good. Check the fit of the two parts as 35 years can show some wear. If there is wear the only option is replacement. Also check for tiny rust pits on the moving surface as that will cut a seal to bits in no time flat.
15Back to top Go down   Fork seal leaking Empty Re: Fork seal leaking Mon Nov 16, 2020 7:51 pm
Forks used in K's ;
Fork seal leaking 91601482_648657772619577_5910241471675498496_n.jpg?_nc_cat=108&ccb=2&_nc_sid=730e14&_nc_ohc=vd2hhkgrvGgAX86-RcU&_nc_ht=scontent-ams4-1
Fork seal leaking Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
16Back to top Go down   Fork seal leaking Empty Re: Fork seal leaking Tue Nov 17, 2020 4:53 am
Timos
Timos
RicK G wrote:I have had very limited success with any of the aftermarket seals but genuine OEM have always been good.
I’ve ordered some OEM seals from Motobins.
The chrome on the legs is good, but I will check the slider to leg fit.
Thanks for the help.
17Back to top Go down   Fork seal leaking Empty Re: Fork seal leaking Tue Nov 17, 2020 10:34 am
Corkboy
Corkboy
And gaiters always  fit gaiters (as you will have the forks apart anyway.
Otherwise, even with the OEM seals, they will eventually leak again.
Since fitting gaiters, problem went away.
             '87 K100RS 0140995 (Gone)
             '97 K1100LT 0188024 (Gone)
             '08 Transalp 700
18Back to top Go down   Fork seal leaking Empty Re: Fork seal leaking Tue Nov 17, 2020 10:38 am
Corkboy wrote:And gaiters always  fit gaiters (as you will have the forks apart anyway.
+5 (the number of bricks I've put them on)  No leaks so far(knock on wood).
They also help in the BMW "look" of the bike by hiding those shiny fork stanchions.
19Back to top Go down   Fork seal leaking Empty Re: Fork seal leaking Wed Nov 18, 2020 4:23 am
And do NOT use aftermarket ones. They won't last. Yes, they're half the price (or less) than OEM, but last less than a tenth of the time.
