Jtoregan
Jtoregan
https://photos.app.goo.gl/n5FAH7UrXshb8B1k9
 I'm close to taking the frame off, and I'm stuck on this electrical plug that won't come out. It's the one that runs along the temperature sensor, which was also difficult to get out, but even with two pliers this one won't come out. Any pointers?
That's the oil pressure switch lead. See the small hump and slot facing you? Take a small 'jeweller's screwdriver' and slide it under the front edge of the female connector block to lift it up far enough to pull the male connector out. If it's well and truly stuck, then cut the bugger off and replace it with a couple of 3.5mm Japanese terminals Very Happy
Actually, looking at the photo, you've inadvertently done enough damage to the wires to make cutting it off the best option.
Jtoregan
Jtoregan
Yea screwdriver didn't work either. Snips made quick work of it though, thanks for the response
Jtoregan
Jtoregan
Complete electrical noob here, would these work?
https://www.hobbytown.com/eflite-3.5mm-gold-bullet-connector-set-w-heatshrink-3-male-3-female-efla241/p39357
Jtoregan
Jtoregan
Apologies - 3.5mm was a typo; it should have been 3.9mm. Search ebay for 'japanese bullet connector'. You want (preferably) this type:
https://www.ebay.com/itm/296217884721
It does mean buying the correct crimp tool but I'm willing to make a good guess that you'll find a use for more of them further down the line.
https://www.ebay.com/itm/204866624050
Damn. I wish I could have got the crimp tool that cheap in the UK!!
Jtoregan
Jtoregan
Got it! I appreciate the help!
