1Back to top Go down   Engine to frame bolt   Empty Engine to frame bolt Sun Apr 08, 2012 3:13 pm
nino
Hello, I need a little help from somebody who should know. I lost the engine to frame bolt on my k 100 /1983. Try to find it in motobins, no luck, try in OEM parts page, cant see it. The only way is to find it in some workshops, but dimension looks strange, somewhere between 7 and 8 mm.
Anybody knows correct dimension?
2Back to top Go down   Engine to frame bolt   Empty Re: Engine to frame bolt Sun Apr 08, 2012 3:26 pm
nino
nino wrote:Hello, I need a little help from somebody who should know. I lost the engine to frame bolt on my k 100 /1983. Try to find it in motobins, no luck, try in OEM parts page, cant see it. The only way is to find it in some workshops, but dimension looks strange, somewhere between 7 and 8 mm.
Or between 8 and 10 mm
3Back to top Go down   Engine to frame bolt   Empty Re: Engine to frame bolt Sun Apr 08, 2012 3:29 pm
Right side: M10x45.
Left side: M10x60.
4Back to top Go down   Engine to frame bolt   Empty Re: Engine to frame bolt Sun Apr 08, 2012 3:39 pm
nino
Thanks Inge. Is it fine or normal thread?
5Back to top Go down   Engine to frame bolt   Empty Re: Engine to frame bolt Sun Apr 08, 2012 3:42 pm
nino wrote:Thanks Inge. Is it fine or normal thread?
Normal 1,5 mm pitch threads.
If you lost the one on the left side, it could be that a shims between the engine and frame also is missing.
6Back to top Go down   Engine to frame bolt   Empty Re: Engine to frame bolt Sun Apr 08, 2012 5:14 pm
nino
Thats early type 1983 without rubber gromet and shim
7Back to top Go down   Engine to frame bolt   Empty Re: Engine to frame bolt Sun Apr 08, 2012 5:32 pm
Rubber bushings is only used on fairing models.
According to parts manual it should be shims present (if needed),
factory workshop manual says no shims on your model.
I would trust the factory manual....but if it is a distance present I would have mounted a shim, to avoid stress on the frame.
Engine to frame bolt   Ramme11
8Back to top Go down   Engine to frame bolt   Empty Re: Engine to frame bolt Sun Apr 08, 2012 5:40 pm
nino
Inge K. wrote:Rubber bushings is only used on fairing models.
As matter of fact I put the full rt fairing from another bike which normally goes on frame with rubber dampers on the front part of frame. Its probably better but dont believe I can put rubber on the old k 100 frame
9Back to top Go down   Engine to frame bolt   Empty Re: Engine to frame bolt Sun Apr 08, 2012 6:02 pm
nino wrote:As matter of fact I put the full rt fairing from another bike which normally goes on frame with rubber dampers on the front part of frame. Its probably better but dont believe I can put rubber on the old k 100 frame
Then you must drill bigger holes in the mounting lugs, not something you do in the backyard.
BMW recommend to not fit a fairing to the solid mounted frame.
But on the other hand, it`s plenty who have done this, without any problem.
Keep an eye on the welds between the lugs and the tubes now and then.
10Back to top Go down   Engine to frame bolt   Empty Re: Engine to frame bolt Sun Apr 08, 2012 6:08 pm
nino
Thanks Inge, the fairing was really good, complete and I didnt resist. Mounted it properly, the only difference are that bushings. Its looks ok, no vibrations. The only thing I forgot was the contra nur on the left lug which lost somewhere.
