1 Lifting Handle removal Wed Jun 26, 2024 1:22 pm
The job of removing the lifting handle is not one that often needs to be done, hence the lack of information on how to do it for those attempting it for the first time.
I thought I would post some pictures of the technique I use from a recent job. The model in question is a K75c from 1985.
The springs on these have a flat retainer/end plate at either end with a locating hole on the inside for the spring and notches in the frame and handle for torsioning the spring to make it close automatically.
Later models have a V shaped Flat steel spring retainer which makes it slightly easier to remove and should be self explanatory when looking at it on the bike.
Wear hand and Eye protection as these springs are strong!
Tools needed are:
After allowing the oil to soak grab the rear facing retaining plate with the grips and pull hard while twisting, This moves it out of the retaining grooves. Keep pulling back whilst you or your assistant jams the screwdriver between the coils of the spring to hold the tension and stop the spring retracting into the frame.
You can now start to wriggle the plate on the spring to work it off, It will be stuck with some corrosion .
I found that by slipping the lifting handle over the nose of the vice grips it gave me a great method of putting sideways pressure on the plate to work it off the spring.
Here is what the parts look like separated.
Once the plate is off the spring your handle lifts away and the other plate and spring can be puled through the tube from the front end.
I hope that helps someone.
Tools needed are:
- Penetrating oil.
- A small narrow nosed Locking pliers or Vice grips (I use the latter).
- A narrow Flat blade screwdriver.
- Possibly a strong assistant!
88....May contain nuts!
K75RTP - 1994
